320i to 325i what do i need
cruizin4dirty1s
Post Mon Dec 01, 2008 6:33 pm
i have an 89 320i and the head is gone just wondering what i will need to change it over do i need an ecu wiring loom and gearbox or does the gearbox fit since thier both m20's
Cloggy Saint
Post Mon Dec 01, 2008 6:38 pm
It's all plug & play mate. Gearbox will fit but the 2.0 ratios aren't ideally suited to the 2.5, likewise the diff' but it'll all be fine (about time this was made a sticky!)
cruizin4dirty1s
Post Mon Dec 01, 2008 6:41 pm
how will the different ratios affect it and i was thinkin of gettin a 325 lsd anyway would this make a difference do i have to change the ecu
Cloggy Saint
Post Mon Dec 01, 2008 6:45 pm
yeah, forgot to mention, you'll need to put a 2.5 chip in the original ecu. I'm not sure exactly about the ratios, but the gearing may be a bit short. Someone in the know will tell you sooner or later!
cruizin4dirty1s
Post Mon Dec 01, 2008 6:46 pm
where would i get the chip
Post Mon Dec 01, 2008 6:49 pm
I can supply one, either standard or uprated - Mild or Wild.
Cloggy Saint
You could get a chip from Ant or speedtouch, both zone members.
Cloggy Saint
Post Mon Dec 01, 2008 6:50 pm
Speedtouch wrote:I can supply one, either standard or uprated - Mild or Wild.
Does you computer light up every time someone posts the word, chip? :D
cruizin4dirty1s
Post Mon Dec 01, 2008 6:53 pm
how much with wild and what sort of hp would wild give
Post Mon Dec 01, 2008 6:54 pm
Wild is £30 posted and provides up to 192bhp when used in conjunction with 268/268 cam, six-branch and BBTB, around +10bhp on a standard engine.
320ise
Post Mon Dec 01, 2008 6:55 pm
from what i have read in the past the 320i box has the same ratios as a 325i sport (close ratio box) but the 320i unit is not as strong as the sport one (but do the same job in practice) with a 3.91 or 3.64 should drive power wise the same as a sport, i would myself use the 3.64lsd as i find it bit leggyer than the 3.91. not 100% sure if this is all correct i am sure some one will correct me soon if am wrong!
leeparkes
Post Tue Dec 02, 2008 9:45 pm
Im sure you need the b25 air flow meter too!
320 exhaust will be slightly different in diameter causing a bit of a restriction,
other than that its plug and play assuming the lump comes with inlet manifold & TB!
BigBavarian
Post Tue Dec 02, 2008 10:05 pm
If you end up changing the rear diff there is also the option to upgrade the rear brakes from drums to discs, unless your car already has them or is a tourer or cab.
Richard
scottidog
Post Tue Dec 02, 2008 10:08 pm
cruizin4dirty1s wrote:i have an 89 320i and the head is gone just wondering what i will need to change it over do i need an ecu wiring loom and gearbox or does the gearbox fit since thier both m20's
Hi mate. I bought a 320i with a 325 engine in it, it originally belonged to fingerman so it might help if you asked him, this is what mines had fitted to that i think may have been related to the swap, i have the recepts
front timing case
distributer and rotor
ht leads
facelift M20 loom and ecu
M20B25 inlet manifold
M20B25 injectors
M20B25 Throttle body
Idle control valve
Inlet maifold gasket set
Inlet boot
Air flow meter
Crank pulley & crank position sensor
Coolant hoses, stat housing
It says they have swapped the ecu and loom for Motronic If that helps.
Sorry if some of this isnt nessesary but thats whats been done to mine since the engine was fitted by the same people who did the work above.
scottidog
Post Tue Dec 02, 2008 10:11 pm
Sorry i forgot to mention mine still has the 2.0 gearbox and diff which feel fine, if anything it runs out of breath too early...... I also still have the 320 single exhaust pipe fitted center to rear which i really hate as i know for a fact its strangling the crap out of it!!!! And doesnt sound as good either. :?
**BANNED**
Post Thu Dec 04, 2008 12:13 pm
My 2.7 is built from a 320i 4 door,still using the 320 gearbox and clutch,no issues in more than 30,000 miles. I did swap the 4.1 diff for a 3.64,though.
Youth is wasted on the young.
