vtech conversion?
320ise
any one ever done it on e30? if so any links available?
Jon_Bmw
- Dangerous when thinking
Ummm, I doubt it. With revvy engines you need low weight. For low weight you need shite metal, for shite metal you need french....
Need I go on.
Need I go on.
320ise
lol would be nice to have the vtech kick though!
Jon_Bmw
V tac!
e21Jason
Vtec s2000 for sale in the last week on the zone
Jason
Jason
jbh
- Hartge Crew
I'm pretty sure I've seen it done on another forum i visited at some point it was a while ago so cant remember where i seen it done. also seen a red top vauxhall 16 valve fitted to an e30 as well ( i know there's a technical term for the vauxhall engine but to be honest its not a car I've ever been interested in )
e30_singh
If you had a tuned V-Tec lump in an E30 that would be good, a stock one would be robbed for power pulling all that weight around.
Also will have issues with transmission, mating the V-Tec with RWD, there are not many RWD Hondas and the ones that are around like the s2000 would end up costing an arm and a leg.
Rebuild your 2.0 lump and turbo it. Will cost less than trying to stick a V-Tec in there and you will have that same kind of effect but with a proper punch.
si-
pet peev - vtecH is a make of kiddies toy, VTEC is the legendary Honda engine
all that said
an s2k lump in an e30 would be nearly my perfect car
e30's aint all that much heavier than s2k's if they are at all
that would be the only engine you could do it with though all the other b/k series engine's are FWD unless you went for a legend engine 3.2 vtec ...........
GrindCulture
Someone done an S2000 powered E30, 250bhp but fuck all torque. Get yourself a VANOS motor.
Not in E30s any more
ShakeyC
Honda S2000 is about 1.3 ton whats most E30's about the same if not less. The 2.0 F20C is very good engine and the 2.2 F22C having bit more torque but same power with it all moved lower down the rev range by 1000 rpm.
Saying no more don't wish to offend as I disagree with most of the above.
GrindCulture
I'm not saying it wouldn't be an awesome car...
eta
If the gearing is short it will work.
A 2dr 325i weighs 1180 kg.
e30_singh
All this talk but no action, anyone going to do this swap or not?
Trise30rally
First you need to buy an engine and gearbox easily £2500
In order to get the engine sitting low enough (for hadling) you need to dry sump it, the kit alone is around £1500 then you need all of the pipe, fittings, oil tank which easily add up to another £700
Afer that you need to sort the wiring, i have been told the easiest way to do this is to send the original wiring loom to a specialist who will strip it of all the useless stuff and fit a new ecu. another £700
So thats £6400 before you have even fitted it and made a prop, engine mounts etc!
I was going to do this for my rally car but it was too expensive so i decided to fit a vauxhall red top instead!
Heres my progress (p3 onwards)
e30bmlover
- Ac Schnitzer prophet
you took the words out of my mouth!Jon_Bmw wrote:Ummm, I doubt it. With revvy engines you need low weight. For low weight you need shite metal, for shite metal you need french....
Need I go on.
french........... cant build cars, cant fight wars....
Jon_Bmw
They do the occasional good engine though.
MJJ_ZX6RR
Aye. I have two of the Pug V6s, one saloon, one coupe. Coupe is still tight and fault-free at 168k too.Jon_Bmw wrote:They do the occasional good engine though.
Tis a nice engine in a GT luxo-barge type way. Sewing machine smooth, sounds nice and refined, particularly compared to my ASBO silenced E30 335.
Martin
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
