weird knocking noise
kend
Tue Nov 25, 2008 10:09 pm
ant time i let my foot off the power i hear a weird knocking noise comin from the back of the car i think it may be someit to do with the diff any advice would be great thanks kendy :eek: :eek:
Chris-W
Tue Nov 25, 2008 11:14 pm
Diff rear mount bush could well be shot.
gcs325i
Tue Nov 25, 2008 11:22 pm
If the bolts that hold the diff to the rear beam are slack it can cause knocking as well.
hongkongfuey
Mad-tango-geezer
Wed Nov 26, 2008 5:25 pm
axle carrier bushes??? or all of the above
with cars like mine,
abelai
Wed Nov 26, 2008 5:54 pm
Body in boot not as dead as you thought? :mad:
If I can't fix it I'll f**k it up so bad nobody can!!
punk_sy
it could be the diff bearings or teeth if youve been doing a lot of hard pull offs or drifting. Ive blew 3 now and they stated banging and nocking before having no drive at all?!?
cass1_5503
Wed Nov 26, 2008 7:03 pm
sorry to hijack but mine knocks from the rear at initial pulling off once moving its fine. its also there when slowing i replaced axle bushes and trailing arm bushes so i know there ok top mounts are new also the car is a 318 so no roll bar etc.
johnlouis
Fri Nov 28, 2008 8:03 pm
silly point, but mine had a strange ticking which turned out to be one of the bbs wheel centers loose and bobbing about when cruising at low speed... Dont overlook the obvious...
nixy
Sat Nov 29, 2008 12:43 pm
might be the CV joints
