These are what i have
engine with loom converted already
clutch and flywheel (m20)
gearbox (m42)?
gearbox(m20)?
m42 prop
m20 prop
3:25 lsd
rad and pipes
brake servo
stuff i need
e34 throttle cable
water pump and gasket
fan belt
sump and rocker gasket
LSD diff oil
modify the manifolds
another lower half of the e30 steering linkage
325 springs which may be sorted.
Also i need some info on the exhaust system. i still want to have a single exit rear box. so i was thinking that the 320 has a 2 to 1 centre silancer which i have, but the diamater off the pipes look to small as i was thinking of using 2.5" diamater for the system.
has any body tryed this or something else ?
and what diameter pipe would you recomend?
Also am i missing something whats not on the list? i might off forgot
will get pics and diamaters of manifolds and silencer ect.
This is a view under mine from the front,it's difficult to get a decent shot,have a look at my thread in the photo gallery for more of the exhaust(Daimlerman's folly).I have wrapped some exhaust wrap round the down pipes now to hide my welding from the MoT man!!
