e23 same as e28?
joshce
hi i just got a free e23 728i in fair condition
but as e23 parts are trickier to find , im just wonering how many parts would be the same as the e28. would the prop fit an m30 3.5 also things like water pumps alternater and those type of bits
joshce
alright cheers man will do
My first BMW was an E23 728i, B reg in polaris silver. I was 19 at the time!
AndyG
Hi
e23 parts are quite easy to come by, many get broken so dependent on wht you're after they can be sourced, I can normally get my hands on a number of parts. However the local BMW dealer can get any e23 part at the moment but on a 4 day order from Germany AND they're not as expensive as you may think
e28 and e24 items can fit (engine wise the same m30 lump etc) just do a cross check on some of the web sites out there or part nos.
Andyboy
- Alpina Colada
I had an R reg 728 manual in 1986, metallic green heap of shit. It had been hit in the back wing and had so much filler, the fuel filler cap was recessed by about 20mm.bss325i wrote:My first BMW was an E23 728i, B reg in polaris silver. I was 19 at the time!
It had green cloth trim, did about 15 mpg and drove like the Bismarck.
ULF401R rust in peace.
robbo86
You git barry.... my car at 19 was a micra, moving onto my rover!bss325i wrote:My first BMW was an E23 728i, B reg in polaris silver. I was 19 at the time!
It was a tank but knida cool to smoke about in till i killed the auto gearbox.
I replaced it with a Sierra saphire 2.0i Ghia.
and thats where it all went wrong for a long time!
Booo!Simon13 wrote:and thats where it all went wrong for a long time!
Andyboy
- Alpina Colada
Nothing wrong with a Staffire Ghia with an injected Pinto and a Type 9. With a decent set of dampers fitted they were a pretty good car.
Yep, it was pinto injection and type 9'd and in metalic blue. Funny you should say that about the dampers, i put a Koni shock and spring kit on it. That along with some new bushe's, TCA's and decent rubber was a fun car.Andyboy wrote:Nothing wrong with a Staffire Ghia with an injected Pinto and a Type 9. With a decent set of dampers fitted they were a pretty good car.
Just needed an LSD.
