Shhhhhh, the loom has to come out first so we'll worry about that later!!lol.320Touring wrote:Matt- it actually looks to be not too bad an old tub..
mind u, aint seen the bulkhead yet
Just a couple of pics before the camera died, will get more later....
Right folks, a couple of questions....
How do you remove the trim from round the top of the doors and the door pillar?? didn't want to come off too easily so I just left it.
Is the foam piece on the rear pillars available from the stealers?? If so I'll whap them off and buy new ones...
Whats the best way to remove the wiring loom?? It's all labeled up and removed from the boot area and sunroof, removed the dash part and labeled it, does it all have to go out through the hold bellow the fuse box and is it best to do this when the brake servo/ engine is out?? If so I'll do that first.
also I seem to recall that I have seen a diagram for the accessories socket for what plugs in where?? Anyone got this, cause a couple of plugs fell out and I just want to check where they go...
And finally how do you remove the door locks?? Can't quite see what happens there, looks like a clip in thing but don't want to damage.
Cheers Paul.
