M42 into M40
ianclapham
i have just bought a 1989 e30 with a m40 lump for road rallying, if i can find a m42 engine what kind of a job is it to put into my standard m40 car.
thanks
ian clapham
thanks
ian clapham
GrindCulture
Easy as pie to do. If you can find an engine with all needed ancillaries (mounts, loom, exhaust system, ECU etc.), gear box and proshaft, it literally just swaps in where the M40 went. The only extra little bit is welding the coilpack bracket onto the o/s wing. You can avoid doing this by doing a coil-on-plug conversion using a home-made bracket and M54 coils.
The M40-M42 swap was my first major mechanical undertaking, with very little experience in anything else bar basic servicing. That's how easy it is
Not in E30s any more
yes but you would need all original e30 IS mountings.....
I have just bought an IS engine for the conversion and will be tackling it if I can find a decent sized garage, otherwise wating till the weather improves and doing it in my mates garden.
http://www.e30zone.net/modules.php?name ... c&t=112713
check this thread, I have asked jus about every anally retentive question known to man on this conversion in that thread. Should answer most, if not all your questions, there was an IS engine for sale about the time I bought mine, might still be available.
GrindCulture
M40 propshaft does not work if you're using the M42 gearbox. I found this out just as I thought I'd finished, then realised that the centre bearing was wankered...
cass1_5503
for this you would need to change the sump and timing covers i think not sure if the gearing of the e36 box is the same as the e30 one, if it was me i would wait for e30 items to pop up they do every now and then.320ise wrote:would e36 i.s items fit?
the e36 318is gear box has a straight through 5th gear and the e30 box has a straight thought 4th gear and an overdrive 5th or a geared up 5th . if you fitted an e36 box it would be reving high in 5th like you where driving it 4th gear .320ise wrote:will the e36 i.s gear box fit? allso why do you have to change the prop thought 318i/is used the same? would e36 prop be ok to use?
GrindCulture
The only way you would compensate for the E36 box would be to fit a different ratio diff, but even this it would be hard to get it right.
Sorry I am not far off fitting an IS engine with an IS box. What do you mean by this! i know I porobably sound pretty thick but..... well...... I am!the e36 318is gear box has a straight through 5th gear and the e30 box has a straight thought 4th gear and an overdrive 5th or a geared up 5th . if you fitted an e36 box it would be reving high in 5th like you where driving it 4th gear .
Had to read that a couple of times to figure out what you mant, but I get you now.monkey wrote:5th gear is the same as 4th on an e30 box = e36 gearbox in to an e30 means the engine will be reving it nuts off all the time as the gear ratios will be too low
