clutch release bearing help please
ive a whirring on operating the clutch and have been told its the clutch release bearing on my 325i---anyone any advice on how easy/difficult to do???---i know it means the gearbox out but is this difficult aswell--me and my old man have done loads on cars-but never a gearbox----sorry just to clarify-its whirring while its stood still-when i depress the clutch it goes.
- Brianmoooore
Chances are you're hearing the typical layshaft bearing rattle that afflicts E30 gearboxes.
I would expect a duff clutch release bearing to protest loudly when the clutch is operated.
SilverShadow
- Hartge Crew
When I done my engine swap i changed my bearing, but it made the same noise but even louder!
I been actually thinking of some how getting some oil on it by taking the slave cylinder off? just and idea though.
I guess to take the gear box off is a bit of a job you would need around 3 feet of extensions to get to the gearbox bolts!
SPADGE
Great idea lots of slippery oil all adjacent to your clutchSilverShadow wrote: I been actually thinking of some how getting some oil on it by taking the slave cylinder off? just and idea though.
- Brianmoooore
shane21 wrote: just to clarify-its whirring while its stood still-when i depress the clutch it goes.
Make your mind up! Which is it??only makes noise when clutch is depressed????
If the noise occurs when the pedal is pressed, then it is the release bearing.
d'oh!!!!----its just doin it all the time--if i put my foot on the clutch pedal while the engine is running it kinda feels like its juddering-the the noise gets worse when i press the pedal---its buggered i gather!!
SPADGE
The only way to find out exactly what is wrong is to remove the gearboxshane21 wrote:d'oh!!!!----its just doin it all the time--if i put my foot on the clutch pedal while the engine is running it kinda feels like its juddering-the the noise gets worse when i press the pedal---its buggered i gather!!
Anything else will be pure speculation.
