Respraying front valance
Post Sun Nov 09, 2008 2:39 pm
Is it fine to DIY respray a front valance because of the surface is different to the rest of the body work?
town325i
Post Sun Nov 09, 2008 4:22 pm
you can do but have you got a compressor or are you using arsehole cans i smoothed mine with primer so i kept the stone chip protector underneath
Post Sun Nov 09, 2008 4:53 pm
Arsehole cans
Post Sun Nov 09, 2008 5:30 pm
mums partner did his 325i touring with what we are calling "arsehole cans" :P and it came out fine but he done it in the wrong colour :roll: but it was better than it was before it was well shagged
Post Sun Nov 09, 2008 5:31 pm
make sure you prep it properly and use primer :D
Post Sun Nov 09, 2008 5:33 pm
here is a pic of it, was sprayed in audi silver or summin, they did't have larches silver in halfords :roll:
Post Sun Nov 09, 2008 9:34 pm
They still sell the cans at the dealer don't they?
Post Sun Nov 09, 2008 9:35 pm
yep
town325i
Post Sun Nov 09, 2008 10:00 pm
the only problem with aerosol is that the paint is like water and can run easily as you have no control over how its mixed and it has extra addatives to make it work for aerosol cans
Post Sun Nov 09, 2008 11:54 pm
town325i wrote:the only problem with aerosol is that the paint is like water and can run easily as you have no control over how its mixed and it has extra addatives to make it work for aerosol cans
What precautions should I take to stop this from happening?
robbo86
Post Mon Nov 10, 2008 12:33 am
There is a write up in this months practical classics about how to do good repairs using rattle cans. Or borrow it if someone you know is a regular reader.
Post Mon Nov 10, 2008 1:27 pm
shake it well for a few mins
Jon_Bmw
Dangerous when thinking
Post Mon Nov 10, 2008 1:34 pm
Because it has the stone chip(textured finish) you would have to be so heavy handed to get it totally wrong with a rattle can. The textured finish allows you a massive margin of error.
The only problem is that it takes a long time to remove all the old paint due to the different layers you get with stone chip. Once removed, recoat with at least 2 layers of stone chip, then paint with your lazer blue rattle can another 2 coats, then 3 coats of lacquer.
I am lucky that the stone chip is black so that when the stones inevitably chip the diamond black BMW colour its black underneath.
gooner1
Out humping Reindeer
Post Mon Nov 10, 2008 1:36 pm
Blitz, done mine with a a rattle can. Rub down valance to get a key, spray with plastic primer.
Spray coulour of choice,then a clear laquer. Not bodyshop quality perhaps, but not bodyshop money either.
Happy with my results.
clarko74
Post Mon Nov 10, 2008 1:40 pm
I'm going to be spraying my m tech 1 front spoiler soon and was planning on using rattle cans from the stealer, does anyone have an idea of how many cans I'll need for the job?
clarko74
town325i
Post Tue Nov 11, 2008 8:19 pm
best wat is heat the panel up a little so it is worm with a heat gun so the paint dries a little faster and worm the can up a little to make the paint worm (but not to much as the can will explode and paint will be everywhere)
JMRe30
Post Thu Nov 13, 2008 10:02 pm
clarko74 wrote:I'm going to be spraying my m tech 1 front spoiler soon and was planning on using rattle cans from the stealer, does anyone have an idea of how many cans I'll need for the job?
many, i painted my mirrors with 4 cans and was still short. im talkin about the 150ml cans which i was told are the only size they have.
clarko74
Post Fri Nov 14, 2008 9:10 am
Ok, I'll stock up on a few then. Cheers.
