Rims question
bpui
Post Sat Nov 01, 2008 5:46 am
Hi guys ... wonder if i can fit this rim into my e30 or not. i need some technical opinion if this rim going to be deep dish looking.
Work Meister SP1
SIZE : 16" x 7 front / 8J rear
HOLE : 4
PCD : 100
OFFSET : 35
StuBeeDoo
Post Sat Nov 01, 2008 6:05 am
You'll need spacers. Correct offset on an E30 is 24mm on 7" rims and 12 or 13mm on 8".
HTH
Stuart.
bpui
Post Sat Nov 01, 2008 6:18 am
Thanks alot .. one more question.. what about offset for 17x7 rims?
whats the correct perfect fitment for e30?
BadDave
Post Sat Nov 01, 2008 10:46 am
bpui wrote:Thanks alot .. one more question.. what about offset for 17x7 rims?
StuBeeDoo wrote:Correct offset on an E30 is 24mm on 7" rims
bpui
Post Sat Nov 01, 2008 4:47 pm
Ohhh ... alright thanx ... doesnt matter how big is the diameter of the rim ..
BadDave
Post Sat Nov 01, 2008 5:23 pm
Nope. it's all to do with rim WIDTH
jaistanley
Post Tue Nov 04, 2008 2:22 pm
Actually, From a handling standpoint, it also depends on the rolling radius.....
bpui
Post Tue Nov 04, 2008 5:06 pm
what about 16inch pcd100 8jj offset25?
do i still need spacer?
