I was reading a post by Andyboy recently on this which involves swapping the crank, con rods and cams from the M52 B28.
The boys in the US with access to the US S50/S52 engines are doing 2.9L and higher stroker conversions using the S50/S52 parts.
Has anyone on this board done this? What compression ratio do you end up with and is there a need for a remap / rechip?
Perhaps Andrew can chip in.
