best diff for M30?
blingsta
- Boost Junkie
Dont know what diff im using at the moment, but 90mph is at 4.5k rpms in 5th gear !!!!
what is recommended for a better ratio?
Karan
e30 m3 3.15
- E30 Zone Meets/Events Team
I'd say you,ve got a 4.1 or 4.2 by sounds of it.
I've got a 3.46 on mine which is supposed to be the right one.
But , doesn't it depend on what gearbox you've got, m30 or m40/2
blingsta
- Boost Junkie
gearbox is e28 dogleg..
I think johns got the same g/box as you (slowest m30 conversion).Speak to him as he's got a better idea as what to use.
blingsta
- Boost Junkie
Whats his username?rav320uk wrote:I think johns got the same g/box as you (slowest m30 conversion).Speak to him as he's got a better idea as what to use.
http://www.e30zone.net/modules.php?name ... c&t=115721
His name is johnl320 and is using a dogleg box on the link above
Ziggy
Isn't the dogleg box 1:1 5th? If so, you'd want a 3.46 or possibly even a 3.15.
I've got a 3.64 with the non-dogleg E28 box, & I've contemplated swapping it to a 3.46 but probably won't.
blingsta
- Boost Junkie
i'll start hunting for a e30 m3 diff then ..
ric325i
i hope you enjoying that super short diff
mine is the same, its fun in some ways but not in others.
for us with the e34 box its like ziggy said 3.64 is the way to go.
it feels like a very different beast!
if your going for the m3 diff im sure you will feel the difference! the way it pulls will put a much bigger smile on your face.
blingsta
- Boost Junkie
ric325i
that small case isnt the best. you must remember 'doing a gareth' ??? his small case diff only lasted a few hard starts at the pod, then locked both wheels solid.
game over.
i dont advise you being too harsh on that little thing with that big lump.
im trying to get my hands on a 3.64 meduim diff for my m30.
with the longer diff you feel the torque for longer, you feel it in your guts. with the small case diff you feel it and then its gone straight away.
i was dissapointed with the m30 with my small case. because you dont feel the torque the engine doesnt feel as strong as it does with a longer diff.
I should be ok then as i've got the 3.46 open mediumcase diff
johnl320
3.15 diff 70mph at 3086rpm
3.07 diff 70mph at 3008rpm ( this is what I've got)
2.93 diff 70mph at 2870rpm (this is what I want )
my diff will give me 93mph at 4000rpm
HTH
john
HTH
john
tomson
Manual E34 535i's have a 3.64 ratio so if you are using the gearbox from one this will be the best ratio, according to BMW anyhow
Theo
E34's have a bigger overall rolling radius due to balloon spec tyres, so to get the equivalent gearing on the E30 you would have to either have huuge tyre walls, or a taller ratio diff.
johnl320
He's not, its an E28 dogleg 1:1 5th geartomson wrote:Manual E34 535i's have a 3.64 ratio so if you are using the gearbox from one this will be the best ratio, according to BMW anyhow
john
blingsta
- Boost Junkie
so best would be a 2.93 then!johnl320 wrote:3.15 diff 70mph at 3086rpm
HTH
john
blingsta
- Boost Junkie
ive got the opportunity of getting a 3.64 LSD.. would that be better than what i already have?
johnl320
2.93 and 3.07 both come from E28 525e. Earlier ones had the 2.93
HTH
john
HTH
john
johnl320
3.64 will give you 70mph at 3566rpmblingsta wrote:ive got the opportunity of getting a 3.64 LSD.. would that be better than what i already have?
128mph at 6500rpm
hth
john
John, what will 3.46 give, bearing int mind, i'm using the 535 manual box, and 16" alpinas with 205 x 50 x 16 tyres?????
johnl320
I think your fifth gear is an over drive so 0.81 in 1 out. Someone correct me if I'm wrong.
If so results will be
70mph at 2724 rpm
167mph at 6500rpm
In my opinion thats perfect for this conversion, proper cruiser
but it will still be very lively
john
70mph at 2724 rpm
167mph at 6500rpm
john
nickso
- Location: Go do that voodoo that you do so welllllllll!!
i had 3.46 lsd on mine (pictonroad has it now) it was pretty good with that in it. 2nd and 3rd were fabulous
'88 e30 328i M52 track bint.
johnl320
Sorry, heavily edited, Misread your PM. a 2.91 is ideal
HTH
john
HTH
john
