M30 Tuning
- jimmyjim69er
Hi i am newish to this forum. I have a white e30 touring i have done a few trackdays in and am looking at doing a M30 conversion, i have recived lots of useful info off of the forum. Cheers Lads.
But i am trying to find out how tunable the M30 is and if so what are the sensible mod's and where's the best place to go for cam, manifold, chip ect.....
Cheers James
Cheers James
I sell a good chip for the M30B35, for just £30 posted - as recommended by several Zoners.
GrindCulture
Turbo it
Not in E30s any more
Yeah, turbo is where it's at.
You can spend quite a lot of cash on mods for n/a and you won't get huge gains.
Speedtouch's chip is a good, cheap and worthwhile mod by all accounts though.
- E30 Zone Meets/Events Team
- Contact:
I tried to ask the question on a bbtb on this as the reply was not worth doing.
If it is worth it, what are the gains in terms of extra horses???
GrindCulture
What about Nitrous Oxide?
Andy335Touring
- Contact:
A cam and a chip will get you a worth while gain(240bhp APX), any more stuff like head work/etc is not so worth it on a £££ V's BHP gain basis.
GrindCulture
Forget what the Fast and the Furious makes nitrous oxide out to be.
Set it to inject automatically between 2-5k (or whatever) when it's turned on, up to an extra 100hp that you can turn off? We know these motors can take a lot of punishment so nitrous shouldn't be a problem as long as it's set up properly.
- Contact:
I might take Andy335 advice and do a cam and chip change, but what cam???? as i'll get the chip from Speedy boy
Andy335Touring
- Contact:
Head work on an otherwise stock engine will only get you about 10bhp/10lbft, if you have a cam already in there then then you might get around 15bhp gains, but it all depends on how healthy your engine is and how well the chip matches your mods.
Andy335Touring
- Contact:
I used a shchrick(sp?) but Cat cams are supposed to be good, you get more choice on the duration you want, with shchrick you only get one duration.rav320uk wrote:I might take Andy335 advice and do a cam and chip change, but what cam???? as i'll get the chip from Speedy boy
Andy335Touring
- Contact:
not sure off hand what the durations are of the cat cams, mine was a 284/280 which is fine for the road so pick one around that but no higher
GrindCulture
Isn't the M30 grunty enough on its own for a road E30?rav320uk wrote:Well my car is not for track, only road use, so what would you advice on the catcams
- Contact:
No, i don't think so, will be happy with about 240+ bhp to beat all the scoobys and mitsubushi boys round here
Turbo is where it is. always.
M30 turbo is something to be admired,
ultra low end in NA form, little boost now in the low end,
high end always loosing VE. So boost helps you straight line the power to 350hp EASY.
GrindCulture wrote:Isn't the M30 grunty enough on its own for a road E30?
no.
who doesnt want more power???
if your going turbo its not going to be a daily driver anymore. we all want a go in a turbo'd m30!!!!!!!!!!!!
if you want power its the way for mental power!!!!!! but if i wanted that power i would start with a rice lump thats already turbo'd. few on here are trying it and looking good.
unless you were as luck as driftboy and buy toby unna's full set up
ric325i wrote:GrindCulture wrote:Isn't the M30 grunty enough on its own for a road E30?
no.
unless you were as luck as driftboy and buy toby unna's full set uplucky get.
its alright haveing loads of power but its handling aswell!!!!!!
why can´t turbo´s be dailys?ric325i wrote:GrindCulture wrote:Isn't the M30 grunty enough on its own for a road E30?
no.
They aren´t when things are not done right, but when done right they can be.
GrindCulture
no.
as the old saying goes, power is nothing without control.jaffro wrote:ric325i wrote:GrindCulture wrote:Isn't the M30 grunty enough on its own for a road E30?
no.
1an wrote:as the old saying goes, power is nothing without control.
yes yes.
lets face it the e30 would be happy with 350bhp. maybe you will need to make the diff holder stronger???
i think 300 to 350 would be the nuts and controlable in an e30.
i think Unna had a good laugh in his
thats my daily driver thought. maybe he could have had it mapped better????
Gunni wrote:why can´t turbo´s be dailys?
ok your right. i would just be worried if i was sat in rush hour in manchester, well i am anyway....i cant take my eyes off the temp in any car.
- Contact:
WHAT!!!! you having a laugh as I was going to ask you to help me do my e21 m30 conversion.I think i'll have a go at this one, as I've done most of the other myself too.na chance ive retired lol
Now that is something I'd like to see.rav320uk wrote:[my e21 m30 conversion.
Pleeeaaase post pics when you do that, I adore E21s!
Hi, take note the following, it may help you in the process..
I wouldnt go into the m30 to get power. Its not a 5.0. Itr, wasnt built in mexico, it is pretty good striaght form the factory. cruising other boards and this one, i came up with the folllowing a long time ago, i have one E30/m30.
Zone chip, EAT chip or JC (about 229bhp) Most intellegiant people would stop there.
Exhasut: No reliable dyno stats to show more than 5 hp to the ground
Porting and polishing intake manifold and installing mustang injectors ~ definite improvement on torque but no reliable HP gain dyno (But I know its there)
Header...again 6 to 7 seven ont he ground,l maybe
Tuning AFM..big help
REplacing AFM with MAF..good for about 5% over entire powerband and 15% on top end
VArious cold air intakes..meh..simply insulating what you have..good for 1 or 2 HP
Cams make you lose precious low end
Lightwieght flywheel..increases effective horsepower by reducing rotating inertia. A big improvement right there! I rode in a car with magnaflow exhaust, EAT chip, and lightwieght flywheel..it was amazing.
all in all ???
Remember M30 is an 'old scool' engine. With everything I have just mentioned, I have found report after report indicating about 260 HP crank from 'Metric Mechanicis', which is your best bet, but not cheap tho..
Changing to MAF will get you a better POWERBAND..
If you have an pre 88 M30, changing to newer pisotns and heads will get you from the 186 up to the 208 of the newr m30
The cost of all those mods?
Exhaus $700
Headers? $700
Chip? $200
Porting and injectors? $450
The flywheel is a necessity anyway, so I wont count that
MAF? $700 to $1200
if you wants to play around, do a 'dual pressure oil spraybar'. it's an excellent mod, in terms of preventing major problems later. Here is the link.
http://www.cscoupe.org/tech/spray_bar_fix/70590.html
cheers mate.
all in all ???
Exhaus $700
Headers? $700
Chip? $200
MAF? $700 to $1200
cheers mate.
Proud to say, First E30withM30 in Kuwait.
