318 timing chain
Kelvfoozinda
Just thinking of buying a 318IS, bloke says it has a noisy timing chain. What can sorting this involve? New guides and chain? Oh, and how much is it likely to cost me in parts/labour or is it easy enough to do myself (can do most car/engine work with a haynes)?
Kelvfoozinda
Just looked through the online manual thingy and seen what it involves. Looks pretty simple, however how much are the parts likely to cost? Is it best to go BMW?
town325i
i thought an e30 318is is belt driven and the later m44 1.9is engine was chain driven
Cook318IS
nope e30 iS is chain driven. It *could* only need a new tensioner, or it could need a new chain, sprockets, guides, tensioner and all the gaskets needed to get to it aswell.
march109
all chain driven.town325i wrote:i thought an e30 318is is belt driven and the later m44 1.9is engine was chain driven
town325i
o right learn something new every day
Gwynleym10
318IS M42 16V engine in an e30 has a timing chain.
It is perfectly possible to change the chain yourself, you need to budget around £400 in parts though.
Don't bother just replacing the chain without the sprockets - it will make it more likely to jump.
Have a look at;
http://www.e30zone.net/modules.php?name ... highlight= page 3
and
http://www.esatclear.ie/~bpurcell/
You could just replace the timing chain tensioner (£15) and hope for the best. Worst case is that the timing chain slips on snaps (pretty unlikely IMO) and you have to get another engine..probably around £400!
Have a look at;
and
Kelvfoozinda
So funking pricey for parts!? What mileage do the chains normally start rattling at? This is a 125K car i'm looking at.
Gwynleym10
They get noisy about 100k.
Sure it is the chain? Exhaust, injectors etc can make noise.
If your buying the car, make it clear that you know how much it costs to replace the chain!
If the car has rust is far more important and will cost you loads more to sort out.
Kelvfoozinda
But its a 900 quid car, dont want to rush in and have to fork out 400 on the chain etc. Can it be put off, or is it something that really needs doing? Rot wise, its supposed to be good, but i'll have a thorough scout about.
GrindCulture
Chain tensioners cost £33 odd from the dealer, I replaced mine recently and it seems to have quietened down a lot, you still get a bit of noise compared to a belt though (in my experience).
Not in E30s any more
GrindCulture
It's probably £900 for that reason then. You might be able to put it off for a while, but it's difficult to tell when it's going to let go and ruin the engine entirely.Kelvfoozinda wrote:But its a 900 quid car, dont want to rush in and have to fork out 400 on the chain etc. Can it be put off, or is it something that really needs doing? Rot wise, its supposed to be good, but i'll have a thorough scout about.
Gwynleym10
If the rest of the car is good / ok then I think £900 is fine. Try and get him down to £700, but this maybe the reason why it is cheap.
Agreed that timing chain cars make more noise than belt.
Timing chain tensioner is around £15-20 from EuroCarParts, it is the correct part (different to earlier ones) and made by FEBI - which is a manufacture that makes stuff for BMW
Chris-W
Cook318IS
precisely, you can use the timing chain argument saying that it will cost £££'s to fix to bring the price down further
think for me it was about £300 - £350 in parts but i should of bought them through the genuine parts section on the zone instead of my local dealer because they're useless but they did give me some discount i suppose but probably not as cheap as you can get through here.
aj_mckay
£300 - £400 in parts to replace!!??!??!!??
Never thought it would be THAT much... Is that definitely correct?
Cook318IS
Thats how much it cost me
but i bought alot of parts, all geniune bmw parts and i bought every single gasket. The chain alone is about £60! And as said before, you would probabl be able to get it all cheaper through the zone and you may only need a new tensioner - not the full shabang. only the cable + clamp at the bottom of the first pic arent for the timing chain iirc
hope this doesnt scare you!
aj_mckay
Hmm so i could prob get hold of the main bits (chain, sprockets & guides) for about £200 through the zone & Cheltenham BMW i reckon?
My car's done about 115k miles and don't think it's had the chain replaced yet so i will get it done to be safe. I've replaced the tensioner already but that hasn't made any noticable improvement to the noise I get at around the 3k RPM mark.
Do you know of anyone reliable and reasonable who could do the work? I'm based in Oxford but would be willing to travel (within reason) for the right service.
Cook318IS
im not brilliant at geography even though i did a level
(learnt more about soil and tourism than anything else!) But Chris Warburton who has already posted on here is a top notch bmw specialist and even has a price for the job on his website iirc. I got my bmw specialist to fit it afterwards for me and was about £150 in labour but its quite a time consuming job from what ive heard. I replaced my chain at 172k! Bought it on 165k mind.
aj_mckay
Yowza - 172K!
Yea, I've dropped Chris W. an email to ask him some details as he's only a couple of hours away.
I'm not even certain the chain on mine is overly noisy or whether it's just standard for a chain driven engine. I just want it done for peace of mind really and it's gone past the 100k mark so should be done really i s'pose...
Cheers dude
Adam.
Cheers dude
Adam.
Cook318IS
yea sitting at about 174k now... still not half bad with a dynoed 140.1 BHP! i always thought that you could go up to 200k on a chain
you shouldnt get a distinct rattle from it with a healthy chain/tensioner, i could take a video but it'll prob only pick up the singing power steering pump
Kelvfoozinda
Ok cheers for the help and price guide. Just getting a couple of quotes. Cheers, Kelvin.
Gwynleym10
I bought my kit from Cheltham BMW, it was pretty close to £400 in parts.
No point in replacing some of it - probably make it worse!
Not a hard job to do yourself, if you don't rush it and prepare your self with reading before hand.
