Jumpy Rev Counter!!
Kedge
Mon Oct 27, 2008 3:21 pm
Hi folks.
The rev counter in my 325i is jumping all over the place and doesn't seem to match the end revs at all, also the MPG swinger doesn't seem to work.
I have swapped the clocks for another set but this hasn't sorted it.
Can any of you shed some light on this please?
Dave
Instagram - Kedge85
Kedge
Mon Oct 27, 2008 5:30 pm
Also forgot to say the fuel gauge isn't working as well :roll:
Instagram - Kedge85
willisssteve0
Mon Oct 27, 2008 6:12 pm
oo i had the same problem on my 318is found that it was just a nakered fuse check your fuses to see how they look if not not sure hope it helps
johnl320
Mon Oct 27, 2008 11:19 pm
Si board batteries may have given up the ghost. I'd try another set of clocks go through the drama of changing them.
john
Kedge
Tue Oct 28, 2008 11:07 am
Don't the SI board batteries just control the servicelights or are they more involved than that? What kind of battery do i need?
Dave
Instagram - Kedge85
gingebmx
Tue Oct 28, 2008 1:20 pm
Ive got them same problem, this happend after the battery had been disconnected for a day.
So it sounds likely that its something to do with batteries in the dash.
Let me know if you sort this and Ill do the same
Goodluck!
