ONC kilometers to miles
saphireblue
Fri Oct 17, 2008 5:06 pm
Hi
My OBC is showing in kilometers - how can i change it to miles??
smithy318i
Fri Oct 17, 2008 5:09 pm
press the consumption button, then press the small button in the bottom right with a pen to cycle between metric/imperial.
HTH and welcome to the zone.
saphireblue
Fri Oct 17, 2008 5:42 pm
thanks very much will do it now
**BANNED**
The fuel thingy displays three settings,French(litre/klm) American(MPG) and UK(M/G). On the UK setting you also get outside temp in Farinheit(sp!!) instead of Centigrade.
Youth is wasted on the young.
eko
Old timer
Fri Oct 17, 2008 5:55 pm
Anyone know just how accurate the miles left in tank figure is?
smithy318i
Fri Oct 17, 2008 6:00 pm
If it is calibrated correctly and with the correct code plug, very accurate indeed.
You should start to worry when the miles remaining gets to ----
clearly ---- means FUMES in German! :wink:
eko
Old timer
Fri Oct 17, 2008 6:04 pm
smithy318i wrote:If it is calibrated correctly and with the correct code plug, very accurate indeed.
Cool,mine says 83 miles left in tank but petrol light just come on again :roll:
That combined with fluttering temp gauge and dodgy service lights is enough to convince me my si batterys are shot!
Time to replace I think :D
Jon_Bmw
Dangerous when thinking
Fri Oct 17, 2008 6:21 pm
I heard that you could adjust how much it thought was left in the tank. Alas I am a scummer with a clock and can't go out and try it and I can't remember what happened on my old 325.
I'd say they are pretty inaccurate going on ekos example. 80 miles from 6 litres from a 2.5! 8O Thats dreamland territory.
town325i
Fri Oct 17, 2008 6:45 pm
when i had my 325i and brimmed my tank iirc it always came up with 345+. i wish my car would of done 345 miles on a full tank
