S38 wiring
m335
Post Thu Oct 09, 2008 6:48 am
I have a s38 in my 86 325 and Im getting ready to do the wiring. I havent seen any posts about this so Im just wondering if you have to splice into the old fuse box or do you just rewire the wole engine harnes. Or is it just easyer to put megasquirt in and run it full stand alone?
FormerMember
Post Thu Oct 09, 2008 12:21 pm
Use S38 wiring harness for engine. I suppose it's done like M30 wiring harness, so all you need to do is to make new connecting plug at the S38 harness where engine harness connects to body harness.
In E30 the body harness side is basically the round connector at the firewall near fusebox.
You can see it here:
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
m335
Post Thu Oct 09, 2008 3:31 pm
Wow that sounds real easy! I'll look at some M30 swaps and see how they do that and go from there.
FormerMember
Post Thu Oct 09, 2008 6:30 pm
m335 wrote:Wow that sounds real easy! I'll look at some M30 swaps and see how they do that and go from there.
I'm not saying that the wires would be exactly the same, so you need to search correct S38 schematics of course. E30 round connector schemes you can find for example on www.e30.de
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
m335
Post Thu Oct 09, 2008 7:35 pm
Only thing with e30.de is I cant read german. It "shouldnt" be that hard to wire it in tho. Hopefully it will be easyer to wire it then it was to put in.
Post Sat Oct 11, 2008 2:16 am
Try the page translater on the e30.de site by right clicking the mouse, then got to page info and the to translate to english. :cool:
