I'm retrofitting cruise control and I can't see how to fit the clutch switch... Everything else is in except for the clutch switch. The kit came from a LHD American car and is being fitted to an is. Is there a special switch for the is? I cant see where to mount the L shaped bracket and the switch seems too deep (ie it is longer than the distance between the plate with the hole in it to the bulkhead so it wont fit.
