double din radio
cass1_5503
Post Fri Oct 03, 2008 9:13 pm
has anyone ever modified the radio hole to accept a double din radio eg cutting into the switches at the top if so does anyone have any pics
Post Fri Oct 03, 2008 9:14 pm
ive thought about doing that but fitting a large bmw sat nav type one like fitted to the e39
cass1_5503
Post Fri Oct 03, 2008 9:20 pm
thats what i was thinking i thought it would be quite cool
Post Fri Oct 03, 2008 9:25 pm
one of these
http://cgi.ebay.co.uk/BMW-X5-NAVIGATION ... 286.c0.m14
i recon you could if you cusom made a panel or baught a european non clock version and got the hacksaw out, you would probly have to move the hazard and rear window switch to somewhere else like the blank where the air con goes and the hazard to where the window cut of switch is or summin :D
cass1_5503
Post Fri Oct 03, 2008 9:36 pm
aceraf
Post Sat Oct 04, 2008 12:32 am
This would need quite a bit of modding as to fit a double din you'd need to go past the bit that contains the hazard switch etc, and also cut down where the heater controls are aswell. It would be easier to fabricate a whole new panel for that, but not sure how you'd make it fit into the original fixings.
Those head-units will also be pretty heavy so you'll want to make sure that you've got it supported properly somehow.
Would be cool to have the double din though. If i could do it, i'd definitely take the double din over my motorised screen.
Breaking 325i Touring
