Turbo conversion cost?
Gunni
Post Sat Sep 20, 2008 11:40 pm
What have people been spending on their turbo setups.
both bought ones and diy.
I´m talking all plumbing, ecu + tuning, engine conditioning if was needed. exhaust, exhaust manifold and basically the complete package
minus clutch.
When I mean bought I´m talking turn key drive away cost.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sun Sep 21, 2008 9:42 am
im in around 10k at the moment and im still spending.
could have done it for alot less but i bought the best parts for everything to make sure nothing fails..
Gunni
Post Sun Sep 21, 2008 11:06 am
Would you mind posting the parts and services you have bought and your current powerlevel.
Gunni
Colonel Sanders
Post Sun Sep 21, 2008 11:30 am
cant remember everything, but il try.
megasquirt in motronic box with wasted spark
3 msd blaster coils and msd coil wires
lc-1 wideband
holset hx40 16cm exhaust housing
equal length manifold with external wastegate provision, extra braced
tial 44mm wastegate
push fitting boost lines
boost controler
full engine rebuild, new shells, piston rings ect
weighted and balenced low comp pistons
weighted and balenced rods
balenced and polished crank
arp mains and rod studs
arp head studs
full head rebuild with cat cam turbo cam and all new parts
welded and oringed head
ppf adjustable vernier pully
650cc rc injectors
relocated oil filter
m21 diesel oil pump for more pressure on high boost
sachs 618 pressure plate and 6 puk unsprung disc
custom 3" downpipe into 2.5 " straight through exhaust.
large bar and plate intercooler,
2.5" piping
50mm tial bov
there is loads and loads more, but il be here all day if iname everything i have bought, fixed, bought twice.
its all trial and error, and it costs a fortune...
Gunni
Post Sun Sep 21, 2008 6:15 pm
More people??
Gunni
midnight
Post Sun Sep 21, 2008 7:40 pm
stage 3 spec paddle clutch
440ccinjectors
custom swedish plenum inlet maniflod
cosworth throttle body prepped for anti lag
fully rebuilt head with welded water jackets and cat turbo cam
fully rebuilt bottom end
130mm steel h section con rods
non stretch head bolts
walbro 255 fuel pump
brand new forged steel 324 td crank
stainless steel tubular manifold
holset hx40
tial 60mm external wastegate
gm wasted spark conversion
2.7 engine 7.4-1 compression
megasquirt management
straight through exhaust with 1 silencer
rs turbo vibra technics engine mounts
large front mount intercooler
all getting build at the mo
fuzzy
He who sleeps with "Gingers"
Post Sun Sep 21, 2008 7:49 pm
Gunni wrote:More people??
the details of mine is pretty irrelevent on here but the cost is about £5G+ for the engine stuff before upgrading
Phill172
Post Mon Sep 22, 2008 10:31 am
Even though I bought a complete engine/turbo set up, i have rebuilt it already with all new parts and had numerous machining done too.
Overall I have spent about 2.5k at the moment. But it depends how much power you want....
My list at the moment is.
Rebuilt bottem end with all new rod bolts and shells (2.5)
Turbo exhaust manifold (t3)
Decked pistons (7mm)
Welded head
Super T70 Turbo
Turbo cam & Vernier Pulley
Lifters and all other head components
Megasquirt V3.01
50mm external wastegate
Individual throttle bodies & plenum
Front mounted intercooler
Larger oil cooler
Remote mount oil filter
still have a few bits i need to decide and mainly injectors and clutch
Heres some photos
I know the wastegate as been attatched in a wierd way! But that will be changing...!
Gunni
Post Mon Sep 22, 2008 1:25 pm
midnight wrote:stage 3 spec paddle clutch
440ccinjectors
holset hx40
cost?
Gunni
**BANNED**
Post Mon Sep 22, 2008 1:46 pm
When I ordered my zone chip for my 2.7 build I spoke briefly to Ant on the 'phone.He commented that so many dream,but very few commit the cash....a high power engine costs big money,just rebuilding to standard spec. is costly.I would imagine that the cheapest turbo conversion is probably down to Toby Unna,but he is a very competent DiYer/engineer.
Youth is wasted on the young.
e30_Turbo
Boost Junkie
Post Mon Sep 22, 2008 2:06 pm
The initial "get boosted fund " was just £600, manifold, IC, Turbo, charge pipes + various odd bits.
To that I added MS, Injectors, WB and a few odd bits, all in all the first conversion cost me.....around £900/£1000
I've since spent many more ££ on many parts but the overall cost is less than £3k easy.....
I've also had two WB's, Two exhausts, Two Turbo's, Two IC's etc etc plus my boost gauge alone was over £200.
For someone who ' can do ' most themselves it's poss to do it very cheap, to pay someone else, say for 300/350bhp I would expect to see a bill for around £3000/£4000.
You could always ask Gadjit who much it cost him to get 383bhp @ 1 bar :cool:
Gunni
Post Mon Sep 22, 2008 2:44 pm
Ok, just wanted to see what the range is as I´m going to be building one engine that will make no less then 400hp
and then selling off as a package, i.e
rebuilt engine
turbo
manifolds
ecu
all of it basically.
basically a turn key setup fully mapped.
just needed a ball park to request for it when it´s all said and done.
Gunni
GrindCulture
Post Mon Sep 22, 2008 2:49 pm
Chances are you wont get the cash you put into it back if you sell it once it's done.
Not in E30s any more :(
Gunni
Post Mon Sep 22, 2008 3:28 pm
depends on the discounts you have where you buy your stuff ;)
There is not going to be 4k worth of parts in it, obviously selling for 4k would be sort of stupid if the cost is the same ?
Also 4k worth of parts would give ALOT more power that´s $8000, I´d expect no less then 700hp for that money
short list is
stock internals
ported head for improved efficiency
excellent exhaust manifold, split entry and equal lenght,
intake manifold if needed.
100% ideal turbo sized for 400hp and optimum spool.
the only reason I´m building and selling this is for research, experimentation along with paying for the research.
After my research I will posting as much info I can to better the community.
Gunni
Cloud
Mmmmmm Donuts!
Post Mon Sep 22, 2008 10:57 pm
Is the ported head really necessary?
Research is a good idea, and I think the turbo E30 will better the community for whoever buys it.
Gunni
Post Tue Sep 23, 2008 1:28 am
the challenge is to try and create as an efficient engine as I can really.
that means port job and very possibly a cam.
The info from this will better the community I´m hoping and make people realize the potential a m20 has with the right mods and I´m not talking dyno queen dyno charts with no power below 3500rpm
Gunni
midnight
Post Tue Sep 23, 2008 6:46 pm
well adding it up mine will have cost me about £5000, with a few great bargins ive picked up and thats prob gonna be a 450hp + build
Phill172
Post Wed Sep 24, 2008 9:33 am
Have you checked out, E30tech? There is the biggest turbo section I have ever seen on there, so i mean you can always look state side for parts to if that makes it cheaper?
Also guys sorry dont want to be hijacking the thread. I was reading up on some articles and they quote 0-60's of 300rwhp to be under 4 seconds.....this right????
I mean thats serisuoly quick
12345kevin
Post Wed Sep 24, 2008 9:57 am
Gunni wrote:Ok, just wanted to see what the range is as I´m going to be building one engine that will make no less then 400hp
If I was buying a complete rebuilt engine I would want some sort of warranty ! can you afford to rebuild it again at "your" cost if something goes wrong ?
Post Wed Sep 24, 2008 10:02 am
Gunni wrote:the challenge is to try and create as an efficient engine as I can really.
I like it Gunni! Look forward to seeing your end result :cool:
e30_Turbo
Boost Junkie
Post Wed Sep 24, 2008 12:19 pm
Phill172 wrote:Have you checked out, E30tech? There is the biggest turbo section I have ever seen on there, so i mean you can always look state side for parts to if that makes it cheaper?
Bimmerjim recorded a 0-60 of 3.2 secs when running 11.88 @ 110 mph.
That was with no more than 350bhp at the fly.
I'm well into the 5's with mine, so would imagine a setup with a smaller blower would do better as I get little boost in 1st, it waits till 2nd is engaged then rips my fucking head off! LOL
Gunni
Post Wed Sep 24, 2008 12:52 pm
How would it be possible to claim a reason of a problem comes from the engine builder?
Obviously this would be fully mapped, dyno tuned and ready for use.
if nothing goes wrong in that process I can´t see anything going wrong from that point that can be blamed on the engine setup/tune.
Bad fuel and other issues obviously are not problems related to the engine setup.
Checked out e30tech? Yes I have alot.
I´m just seeing what this engine is going to sell for in the UK.
Gunni
**BANNED**
Post Wed Sep 24, 2008 1:02 pm
Without wishing to pee on your bonfire,where is your market? The type of guy who wants a motor of this sort is the type of guy posting,who is well capable of building his own,for whom at least half the fun is in the creating of a unique engine with more grunt than the last one. Could well be a market for a kit of tryed and tested components along the lines of A-techs supercharger kits...
12345kevin
Post Wed Sep 24, 2008 1:03 pm
Unfortunatley the person who has just spent "4k" on an engine may not see it the same way as you. If they did put "bad fuel" into it unknowingly and something went wrong, how would you tell ? If it wasn't sorted promptly, probably at your cost until the facts had been established, then you are likely to have gained a "bad reputation".
Phill172
Post Wed Sep 24, 2008 3:43 pm
I'm well into the 5's with mine, so would imagine a setup with a smaller blower would do better as I get little boost in 1st, it waits till 2nd is engaged then rips my ******* head off! LOL
Serious??? I mean i was getting my head round all of this and thats Pagani Zonda quick!
I really dont know what to expect power wise with mine.....
just running a T70 T3 at around 1 bar.....maybe more if Ant lets me!
Issues with traction fozzy?
Jon_Bmw
Dangerous when thinking
Post Wed Sep 24, 2008 3:56 pm
That would be with heated up drag slicks... I can't see many e30's if any on road tyres getting to 60 in under 4.5 seconds as there just wouldn't be enough grip.
Its not as if you can use your drag slicks on the road is it.
Gunni
Post Wed Sep 24, 2008 4:02 pm
12345kevin wrote:
Gunni wrote:
12345kevin wrote: If I was buying a complete rebuilt engine I would want some sort of warranty ! can you afford to rebuild it again at "your" cost if something goes wrong ?
4k for 400hp engine is a damn bargain.
Tell me anybody in this country that will do
a complete rebuild
extract 400hp
engine management system
turbo
exhaust manifold
intercooler and plumbing
injectors
wastegate
and so on
for 4k.
to daimlerman.
There is no market, I´m just going to develop this one engine and then sell it of to cover cost. I have no interest in starting any retail business from this, This engine will create low rpm boost (1bar by 3k) and retain it upto revlimit(400hp).
Hope this explains things a bit
Gunni
oakey
Post Wed Sep 24, 2008 4:09 pm
I'd be tempted if I had the money. I would without doubt want a warranty though.
Gunni
Post Wed Sep 24, 2008 4:16 pm
4k wouldn´t bring warranty, this would be considered a used engine, used without issues.
Gunni
12345kevin
Post Wed Sep 24, 2008 4:19 pm
Gunni wrote:
12345kevin wrote:
Gunni wrote: How would it be possible to claim a reason of a problem comes from the engine builder?
a complete rebuild
extract 400hp
turbo
exhaust manifold
injectors
wastegate
and so on
for 4k.
to daimlerman.
I used 4k as an example because it was a figure you had used in a previous post ! More K = bigger issues !
I'm not trying to pi$$ on your parade, just pointing out the drawbacks if it dosn't go quite to plan !
Gunni
Post Wed Sep 24, 2008 4:51 pm
Maybe I´ll buy a car to put it in and sell that, might be a better choice.
Gunni
e30_Turbo
Boost Junkie
Jim was running a welded up 2.93 diff and slick tyres and having seen a few of his vids I bet my left bollock he warmed them right up!
What you all have to think about is he "only" did 11.88, there are a few e30's doing 9's so they MUST be doing under 3 secs 0-60 to make that sort of time. Street tires won't allow you do get anywhere near that as you would expect.
I did hear a zoner managed a 11.02 1/4 mile at the pod, away from zoners eyes, he must have hit a low 0-60 for that run!
Phill172 wrote:Issues with traction fozzy?
Yes and No, If I want to have no traction I can, just press harder! There's no way I can have full chat in 1st, 2nd or 3rd without spinning up the wheels, 4th will spin up too but I need to provoke it. I'm only running 10.5psi and I can't see how I would want to go much faster really, I can't think quick enough as it is. When I get another daily to use the red ones getting stripped and boost wound right up, for nowI need it to get to work, hence why I'm such a wimp when it comes to things like the pod, I'd love to play but not at the cost of being car-less again.
e30_Turbo
Boost Junkie
Post Wed Sep 24, 2008 4:57 pm
How's this list to make you sit down and think a little:
1 9.678 @ 147.80 MPH Saku Ritola - E30 Turbo
2 10.319 @ 140.00 MPH Andreas Arthursson - E30 S38 Turbo
3 10.449 @ 141.05 MPH Erik Kilander - E30 S38 Turbo
4 10.623 @ 133.39 MPH Gene Liu - E36 M3 Turbo
5 10.775 @ 134.35 MPH Kenny Shelswell (MrBlonde) - M Coupe Turbo
6 10.785 @ 136.69 MPH Ulysses White(Card Counter) - E36 Turbo
7 10.829 @ 133.96 MPH Thomas Billman - E30 M20 Turbo
8 10.909 @ 136.52 MPH George Kakaletris - E36 M3 Turbo widebody (OEM rubber fitment only)
9 10.919 @ 139.12 MPH Ted Harnell - E36 M3 Turbo
10 10.989 @ 133.00 MPH Andreas Arthursson - E30 M50 Turbo
11 11.115 @ 129.79 MPH Shawn Bowen (ShawnsM) - M Roadster Turbo
12 11.299 @ 125.00 MPH Mike Radowski - E36 M3 turbo
13 11.492 @ 130.40 MPH Blaise Baldeschwiler (Moadster) - M Roadster Turbo
14 11.658 @ 121.84 MPH Justin Givens (BoostedBmr916) - E36 M3 turbo
15 11.679 @ 118.79 MPH Tom Citizen (tampaturboM3) - E36 M3 Turbo
16 11.699 @ 131.00 MPH Omer Sezer (OZM3) - M Coupe Turbo
17 11.719 @ 115.61 MPH Dave N-Citizen (SilverStreak) - Z3 3.0 Roadster Supercharged
18 11.852 @ 118.25 MPH Donovan Citizen (BMW sob) - E30 Turbo
19 11.886 @ 113.76 MPH Jim Citizen (BimmerJim) - E30 M20 Turbo, Nitrous
20 11.985 @ 125.34 MPH Jerry Webb (JMWeb) - E46 M3 Supercharged, Nitrous
si-
Post Wed Sep 24, 2008 7:08 pm
Hi guy's
am new to E30's but have just got myself a very nice little 325i ....this one - http://www.e30zone.net/modules.php?name ... c&t=109585 Warren was planning on eventually turboing it and ive got the same intent.
im not after massive power just a low boost setup, for some sleeper fun but what are these engine capable of as standard? do i defo need to uprate headbolt's gaskets etc? or is forged the only way to go??
im used to Honda's and have put together turbo setup's for them built them etc etc so am capable of engineering a setup and fitting etc.
also does anyone have links to places for parts here or the states as i have ways of bringing in parts from the US of A aswell
mainly can it be done cheaply im in no rush and parts can be bought as and when they turn up i just need to know what parts etc im looking for
cheers for any help
Gunni
Post Wed Sep 24, 2008 7:43 pm
ARP head bolts and you can make your engine run 475whp in with stock internals.
Enjoy the read.
http://www.e30tech.com/forum/showthread ... post706734
Gunni
