starting probs
Sun Jul 03, 2005 10:21 am
That is word for word what I was going to post - No one can know that little about engines!
jaymo
Location: Helston Cornwall and Welwyn Garden City Hertfordshire
Sun Jul 03, 2005 11:40 am
sorry guys, its just happened to me a few times on various cars and i know its happened to others and thats always cured it.
Sun Jul 03, 2005 2:43 pm
jaymo wrote:sorry guys, its just happened to me a few times on various cars and i know its happened to others and thats always cured it.
Distributor cap can be the cause of poor running and of not starting, but in no way is going to stop the engine turning over on the key!
tylerma
Sun Jul 03, 2005 2:45 pm
hey guys thanks for the suggestions
gonna start with the inhibitor switch that Brian mentioned
being an auto it seems like the best place to start
cheers Brian
Sun Jul 03, 2005 2:54 pm
Try the diagnostic socket tests first. If the lamp doen't light, then look at the inhibitor switch. (There's a relay associated with the inhibitor switch as well)
tylerma
Sun Jul 03, 2005 3:01 pm
Brianmoooore wrote:Try the diagnostic socket tests first. If the lamp doen't light, then look at the inhibitor switch. (There's a relay associated with the inhibitor switch as well)
do i try this when the problem occurs?
Sun Jul 03, 2005 3:32 pm
Yes, but it wouldn't hurt to practice first, so you know what should happen.
jaymo
Sun Jul 03, 2005 3:42 pm
It will if the connection it has stopped on has corroded over and thus not providing power to the ht lead. This system is connected thro the ecu to the starter system.
Martinaston
Sun Jul 03, 2005 3:50 pm
jaymo go back to bed mate.
jaymo
Sun Jul 03, 2005 3:52 pm
no need for that mate. I was wrong. sorry.
Sun Jul 03, 2005 10:27 pm
Jaymo, the starter circuit is a fairly simple one - switch, piece of wire, couple of plugs and sockets, starter motor - complicated slightly on an auto by a second switch.
The ECU on an E30 can stop the engine starting, but it has no control whatsoever on the starter motor circuit. This applies to all BMWs up to the introduction of the EWS immobilizer system.
The starter motor circuit would still work if the car were at the bottom of a lake.
stanley
Mon Jul 04, 2005 1:02 am
i'd say its the starter motor solinoid when the solinoid gets hot from driving the brushes in contact with the rotar get glased over and don't conduct hence ign lights on but the engine not turning over, try changing the brushes there cheep and faily easy to fit
Mon Jul 04, 2005 8:58 am
stanley wrote:i'd say its the starter motor solinoid when the solinoid gets hot from driving the brushes in contact with the rotar get glased over and don't conduct hence ign lights on but the engine not turning over, try changing the brushes there cheep and faily easy to fit
OP says no reaction whatsoever when key is turned to start.
The solenoid would still engage the bendix even with worn brushes.
jaymo
Mon Jul 04, 2005 10:59 pm
thnks Brian, I learn something new every day:)
johnono
Tue Jul 05, 2005 12:10 am
Demlotcrew wrote:petrol hoses which are split over the injector rail?
A
ive noticed a little shiney patch just here on mine, and ive always had delays on starting from cold.. could this be the prob?
