2.7 ETA Build Cam Suggestions and Brand Cat or Shrink
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 7:20 pm
Guys
Now i've decided to keep the cab i wanna up the BHP figure on these graphs
Im after some suggestions on a cam??
Also been shopping got some new injectors on route from a E36 M3 winkeye also considering a new fuel reg too
Any thoughts??
Neil
eta
Post Sat Sep 13, 2008 8:00 pm
What is the build spec on the engine, a 731 head with 264 duration cam? Eta exhaust manifold, M20B20 or B25 inlet manifold? Which AFM and trottle body? What injectors?
Ant
Retired Team Member
Retired Team Member
Post Sat Sep 13, 2008 8:05 pm
525E lower CR bottom end
885 head
stock cam and 2-5 inlet mani iirc
Neil, DO NOT fit the E36 M3 injectors !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
nor do you require an FSE
your AFR plot is 11.5:1 @ the top end, there is plenty of fulling in the system as is for the spec of youyr engine dude :thumb:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 8:31 pm
cheers ant, what do u suggest buddy
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 8:40 pm
eta im also running a big bore 2.5 throttle body with alpina 6 branch in addition to the other bits ant has mentioned
**BANNED**
Post Sat Sep 13, 2008 11:11 pm
Put any more umph into that cabbie and you will blow the chrome off!! Seriously,to make a noticable difference will cost big ££,settle for what you have,or stick an M50/52 in winkeye
Youth is wasted on the young.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 11:15 pm
na i dont want to loose the m20 lump got to much :bling: on it now :lol:
Im thinking about a remap and going over to supe ron too
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Sep 13, 2008 11:43 pm
ok i have found my eninge build thread BArry recomend a 272/272 and Ant recormended a 273/273 CAT cam
What benifit would i see running a new cam?? What brand is better I have seen evolve are selling the CAT cam for £220 too
Thanks for ur input guys im lost when it comes to bits like this :o:
reggid
Post Sun Sep 14, 2008 3:14 am
i would run cc273/273 or dr284/272 with the later probably retaining a tad more lowend
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Sep 14, 2008 11:40 am
so with the cams Cat and Shrink is it just branding
ShakeyC
Post Sun Sep 14, 2008 11:53 am
The cat and shrick cams with same the numbers are not actually the same profile, they measure and calculate lift and duration in different ways so a cat 272 and shrick 272 can be very different profiles.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Sep 14, 2008 11:55 am
ShakeyC wrote:The cat and shrick cams with same the numbers are not actually the same profile, they measure and calculate lift and duration in different ways so a cat 272 and shrick 272 can be very different profiles.
nooo more confusion :(
