More update,
Now things made a serious diffrence,
I put in a 325i JimC chip
my buddy arnib has the 320i chip for checking if itԚ´s identical to a stock 325i one or at least close,
6900revlimit
more pull from 4000rpm, just like a 325i starts pulling there, just not as hard obviously,
I havenԚ´t had a chance to do a dyno run nor check mixture, but I will soon,
I do reccomend this stuff if you have it available or can get for very little
325i manifold
325i throttle body
325i intake boot
735i afm bolted to M20 afm filter box,
320i/325i air filter
325i Tuned Chip(JimC or Zone chip maybe)
2.5fpr and 320i injectors.
If today stays dry IԚ´ll do a 0-60mph run
last night I got 9,9 in the pooring rain, with heavy heavy wheel spinning.
If you use a 3.0fpr youԚ´ll be squirting more fuel then a 325i so donԚ´t bother as the 320i injectors are slightly bigger
