m50 320i
whipsey
Post Fri Sep 05, 2008 10:50 pm
would a dodgy afm cause the idle to hunt really badly or could it be a split hose?
stonesie
Post Fri Sep 05, 2008 11:45 pm
I would be looking for air leaks first, carb or brake cleaner is good for this as it eveporates quickly and burns well, so when it finds the leak and gets sucked in it makes the revs rise a little so you can go back and pinpoint it.
More likely to be an air leak
Flozman
Post Fri Sep 05, 2008 11:51 pm
also check the Lambda probe, disconect it and see if the hunting stops.
Post Sat Sep 06, 2008 12:06 am
Id rather fit a 2.5 than fix a 320 flint :)
stonesie
Post Sat Sep 06, 2008 12:09 am
With B28 guts??
Post Sat Sep 06, 2008 12:44 am
Indeed :)
