Post
Fri Sep 05, 2008 5:30 pm
if you look at the far left of this pic you can see rust starting
would i be able to tackle this rust at home without the need of a welder, for example just smoothen it down and respray
sorry if pic aint the best
Elecblondie
Post
Fri Sep 05, 2008 9:02 pm
Personally I'd take a wire brush to it and see if you can get it down to shiny metal with enough left to maintain the arch; looks like you should be able to, to me anyway. Whatever you do get rid of all of the rust, really shiny metal is what you want to see.
Chief_Misfire
Post
Fri Sep 05, 2008 9:03 pm
Send a better pic.
JGG1
- Back in an E30 !
Post
Fri Sep 05, 2008 9:05 pm
From that pic it doesn't look like it needs welding, should be a home job, although paint may not be!
Post
Fri Sep 05, 2008 9:08 pm
will try and attack it with a wire brush, i relise i may have to get paint work done by a pro
gareth
Post
Fri Sep 05, 2008 9:09 pm
chances are it's blown up inside the seam by now. that's not rust under the paint going downwards, it's rust from behind the paint coming up. the reverse side of the lip and inside the seam will be where it's hiding.
i guess the only options are a temporary bodge / seal job or to get the welder out and stop it properly now before it takes the whole arch and back of the sill out. I'd clean it right out with a wire bruish on a grinder and see how you stand. if you're lucky, some polyurethane seam sealer and new paint will keep it at bay for a good few years yet, just catch it now before it has another salty / wet winter to fester (though it feels like winter is here already
Post
Fri Sep 05, 2008 9:12 pm
gareth wrote:chances are it's blown up inside the seam by now. that's not rust under the paint going downwards, it's rust from behind the paint coming up. the reverse side of the lip and inside the seam will be where it's hiding.
if it needs welding it will have to wait till next summer.
the worst part of the rust is sunroof tray it has a nice softspot in there
gareth
Post
Fri Sep 05, 2008 9:15 pm
have a go at cleaning and sealing then. cheap angle grinder £15, wire wheel £5, seam sealer £5, primer and paint £10. If it comes back, weld it! it'll be a smaller job next summer if it does need doing too
Post
Fri Sep 05, 2008 9:20 pm
another quick one
the inner sunroof panel where its rusted, is the only solution a new panel, i want to keep onto of the rust on this one. the rusty patch is only the size of a 10p piece but it will most likely be massive underneith
i take it it will be a big job might be easyier to weld the sunroof up, like non sunroof models
gareth
Post
Fri Sep 05, 2008 9:24 pm
not sure. i've done plenty of wheel arches before (old skool ford man at heart!!!) but not a sunroof panel. afaik, it's a shit of a job!
uless you're talking the slidey / tiltey bit. then just swap it!
simon13's alpina resto thread has details and pics on what's involved in a 'proper' roof panel job...
Post
Fri Sep 05, 2008 9:41 pm
gareth wrote:not sure. i've done plenty of wheel arches before (old skool ford man at heart!!!) but not a sunroof panel. afaik, it's a shit of a job!
no think it will need a new tray at some point, current one will probs last another 10 years yet mind you, but would rather sort it now while you can still get the trays
i will have to pay someone for that
will have a go at the arches if it ever stops raining
Chief_Misfire
Post
Fri Sep 05, 2008 9:54 pm
I have a brand new original BMW tray going very cheap. PM me if interested.
You've gotta out-crazy everyone.
Post
Fri Sep 05, 2008 9:59 pm
Chief_Misfire wrote:I have a brand new original BMW tray going very cheap. PM me if interested.
got no money at moment
is it £5
Chief_Misfire
Post
Fri Sep 05, 2008 10:08 pm
Fraid' not pal.
Maybe you won't need it.
Post
Fri Sep 05, 2008 10:09 pm
Chief_Misfire wrote:Fraid' not pal.
was only kidding
grey_andy
Post
Wed Oct 22, 2008 9:59 pm
I have the same rust on one of my wheel arches, after working at it i discovered this nastyyyy hole running all the way down the arch! SUCKSSS
Post
Thu Oct 23, 2008 8:35 pm
mine aint that bad like
i had a look and its like new there, its just starting so if i catch it early i should be ok
