do i have a lsd or what? cheers
lsd?
fuzzy
who know? it was an option when new so it could be. check out the code on a tag on the diff cover plate. if it starts with S then some numbers iits an lsd. for instance mine is S391 for an 3.91 ratio lsd.
il try thatfuzzy wrote:who know? it was an option when new so it could be. check out the code on a tag on the diff cover plate. if it starts with S then some numbers iits an lsd. for instance mine is S391 for an 3.91 ratio lsd.
wow thats a smart way il try bothjay1980 wrote:Jack up the back end, let the handbrake off, rotate one of the wheels, see which way the other one turns, same direction=lsd, opposite direction=open diff
cheers guys
Globulator
If you are in neutral and just jack up one, handbrake off, it will be very difficult to turn by hand (as it is linked to the wheel on the ground via the lsd.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
more fun way is to drop the clutch with lots of revs and see if it leaves 2 black marks!
Like this, me in my old sport !
Aye George, it went about 3 years ago !
