Weird electrical fault - ideas?
Globulator
Wed Aug 20, 2008 9:24 pm
Bonnet up for charging (as I'm not using it regularly), no key and I'm sitting inside with the door open, courtesy lamp on.
I notice the windows do not work - normally they work without a key if the door is open.
I close the door and the courtesy goes out but stays red. As in red-hot, a tiny bit on.
If I press the window switches now it brightens up,
If I pop out the window cutout on the dash it goes out, reset it comes back on to red.
Has anyone else has this?
Any ideas what to check?
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
eko
Old timer
Wed Aug 20, 2008 9:28 pm
Dodgy door pins?
Wed Aug 20, 2008 9:31 pm
Door pin switch isn't earthing properly to the body?
Globulator
Wed Aug 20, 2008 9:57 pm
When I open any door (2 door 1986 convertible) the courtesy lamp comes on nice and bright .
The courtesy lamp just never goes off properly - it is always red hot unless I pop the window cutout on the dash or switch it off on the lamp.
Globulator
Wed Aug 20, 2008 10:48 pm
Solved:
Fuse 28
Obviously it does rather more than it claims in the manual...
