M-Tec drivers seat help....
Is it possible to replace the ratchet mechanism? (as Im assuming its buggered?)
If mines quite upright (I'm a short arse), it will click itself back 2-3 clicks before locking in.
And while upright, the seat wont lock down, so it'll tip forward if pulled (MOT failure iirc??)
I know the simple answer is leave it back, but I'm at tip toes on the pedals anyway!
Ta muchly!
Ta muchly!
- Brianmoooore
The complete ratchet mechanisms rotate and unclip easily from each side of the seat.
I've had this before and it was just a build up of crap in the mechanism,law wrote:If mines quite upright (I'm a short arse), it will click itself back 2-3 clicks before locking in.
Strip, clean and lubricate did the trick......
4 bolts on the end of each runner to remove the seat.
Take the covers off each mech, 1 plastic screw each side. Remove the seat back cover, 2 screws on the bottom edge and slide up and over the tilt levers. remove the seat back, 2 screws towards the bottom of the back, you will see the mech once the cover is off. Disconnect the tilt cables from the mech and remove the 17mm bolt from the frame and the pin in the centre and the mechs will tilt forward with the help of a screwdriver and pop off.
- Brianmoooore
There's a spring loaded latch that stops each plate from rotating to the point where it simply lifts off.tomson wrote:... and the mechs will tilt forward with the help of a screwdriver and pop off.
Thats why I said with the help of a screwdriver!Brianmoooore wrote:There's a spring loaded latch that stops each plate from rotating to the point where it simply lifts off.tomson wrote:... and the mechs will tilt forward with the help of a screwdriver and pop off.
If he gets that far he should be able to work that out!
- Brianmoooore
Depends what he does with the screwdriver!
Screwdriver, cold chisel, pry bar - all the same thing to me.
- Brianmoooore
You don't need to change anything - just add a few bits.siddiqi1 wrote:guys!
i have four door seats in my 2 door. with this method that you are describing to say, can they be converted to fold?
how would igo about doing that then?
Saboor
The folding mechanism is included on all seats, but the cables, handles and brackets for the handles, aren't fitted.
The brackets are welded to the seat back frame, so the easiest route is probably to find some two door seat backs off of some scrap seats, and swap over the fabric from your seats.
- siddiqi1
- BFG Zone Contributor
ahhh ok
well all these minor pieces can be purchased from the stealers, i would like to have new ones! the seat back may be an issue!
can i notuse some sort bracketry or jubilee clipping system to hold the braket in place instead, though its obv been welded there for strength as well no?
my current seats are sports leather ones so am a bit iffy taking the material off that!!!
- Brianmoooore
Haven't looked up the ETK, but I doubt if the brackets are available separately, so you would have to cut them from a scrap frame, even if you didn't recover it.
Fabric removal and replacement is a simple enough, if time consuming, job.
- siddiqi1
oh ok. tiem consuming im not fussed about, im sad ill spend all day on if i must! its jsut that i dont have a welder so am stuck in that depo!
have to go to stealers to get some washers anyway, so will have a chatty with them and see what i can harness!
thanks for the advice brian
Its simply not worth messing with.siddiqi1 wrote:ahhh ok
4door seats don't have the provision for the tilt cables/pulleys, just source 2 door seats in your trim pattern and sell the 4door ones on after. or find a worn pair of front seats and retrim your bolsters on the backs.....
Globulator
I had one of the top clips fall off my seat and I could not slide the back off because the tilt lever would not come off on the side of the seat back.tomson wrote:Remove the seat back cover, 2 screws on the bottom edge and slide up and over the tilt levers. remove the seat back, 2 screws towards the bottom of the back
How do you get the chair back to clear the lever?? Does it just pull off?
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
Globulator
My seat back was clear on the left hand side but on the right hand side it was attached to the frame by the lever that you move to tilt the seat forward (to allow passengers to get into the back seats) in the middle of the side of the seat back.
There is a bit of plastic that locks the seat back to the seat metalwork, and the lever (pivoting on the seat metalwork) sticks through and ends in the lever. Nothing there wanted to move at all.
I'll try to get a photo in the next day or two.. these are regular leather seats of a two door cab.
- siddiqi1
thanks for the advice buddy! yea it will be more hassle agreed! im being lazy, i cant find a pair of e46 leathers in black for cheap enough at the mo! waiting for those coz i really want the electrics in them!!!!siddiqi1 wrote:
ahhh ok
You need to slide the tilt lever cover off then the other plastic piece you mention will come off, they can be tight if they havent been removed before but they will pop off with some persuasion from a screwdriver or similar.Globulator wrote:I had one of the top clips fall off my seat and I could not slide the back off because the tilt lever would not come off on the side of the seat back.tomson wrote:Remove the seat back cover, 2 screws on the bottom edge and slide up and over the tilt levers. remove the seat back, 2 screws towards the bottom of the back
The seat backs on the passenger seat can be a pain because of the 2 tilt levers but they will come off! I've damaged a few backs in the process so be careful!!
I do have some spare frames in amongst my scrap actually but I'm sure they are convertible ones so the tilt levers are in the wrong place but I will check for you! I'm assuming you want them for the car in your sig?siddiqi1 wrote:thanks for the advice buddy! yea it will be more hassle agreed! im being lazy, i cant find a pair of e46 leathers in black for cheap enough at the mo! waiting for those coz i really want the electrics in them!!!!siddiqi1 wrote:
ahhh ok
