Hi Guys,
Yesterday i drove my car for 50km's with no problem, parked off at home and when i came out again to start the car... nothing! it swings and everything but it doesn't start, if tried push-starting it.
Feul Pump?
Help Need some advice
Guest
ok if the ignition is on do you have any lights...if not battery.
if you have lights on, can you here the fuel pump ticking slightly in the boot?
if you have the lights on, can you here the starter motor ticking slightly in the engine bay?
try hitting the starter motor, also check the leads are ok to the starter motor,
check the body to earth connection
check the battery leads as well
Hope that helps
Hope that helps
fannyj
thanks for the help... appreciated
