tha_lick
Post
Sun Aug 10, 2008 4:50 pm
i wanted to dark out the front of my motor, so i gave it a go... what do you lads think?
cheers
SHAKEELE30
- Boost Junkie
Post
Sun Aug 10, 2008 4:52 pm
well it seems like a good attempt, looking good!
march109
Post
Sun Aug 10, 2008 4:56 pm
Did you use the crosshair thingies?
Jon_Bmw
- Dangerous when thinking
Post
Sun Aug 10, 2008 5:02 pm
You haven't done the main beams yet I presume? Actually in some pictures they look done, others, not so done?
Certainly can't see any normal method(crosshairs) on the main beams...
SHAKEELE30
- Boost Junkie
Post
Sun Aug 10, 2008 5:04 pm
dont look like the crosshairs have been used, plus the beams dont look as dark as the normal headlights....
tha_lick
Post
Sun Aug 10, 2008 5:33 pm
no i didnt do the cross hair, i started them today and finished them today and didnt think to put a cross hair in. maybe my next set i might.
i did smoke the high beam lenses but iv got ice blue bulbs in there so the blues reflecting and making them look purple! aarrghh!
no1_jazz
Post
Sun Aug 10, 2008 5:46 pm
Easy baddd boiii you nto gona sell it then??
u took it off for sale?
Sanchez
Post
Sun Aug 10, 2008 5:57 pm
Did you spray the lenses then?
tha_lick
Post
Sun Aug 10, 2008 6:12 pm
^^^ yeah, i used that Folia tech malarky. done 2 light coats of smoke tint
stonesie
Post
tha_lick wrote:
It looks to me like he has painted the shroud that goes above the bulb, hope you used high temp paint because that thing gets pretty warm
Looks a good job though
tha_lick
Post
Sun Aug 10, 2008 8:39 pm
^^^ yup also painted those too. yeah used high temp paint from halfords
dips346
- London Meets Main Man
Post
Sun Aug 10, 2008 11:16 pm
easyer to spray ...heard you had issus doind it the other way....lol
tha_lick
Post
Mon Aug 11, 2008 7:10 am
^^^ taking the high beams off was a joke. . . had 2 lenses shatter in my hands, then i decided to blow torch it.
other than that it was quite simple
now just need yellow fogs
stonesie
Post
Mon Aug 11, 2008 1:43 pm
I ended up buying the most powerful heatgun B&Q had, and some heat proof gloves.
I took my time and they came off ok
Hyperion
Post
Mon Aug 11, 2008 2:12 pm
i want to give this a try one day too, but i was gonna go the oven route to get the lenses off.
tha_lick
Post
Mon Aug 11, 2008 2:16 pm
i think as long as you can get the adhesive hot you should shatter any lenses. i think i might give it another go with another set of lights and get more of a cruise light theme going on
Sanchez
Post
Mon Aug 11, 2008 6:50 pm
has the spray paint not made your lights dimmer?
If you took the lenses of anyway why didnt you do the normal X hairs and sprayed the chrome ring black.
- **BANNED**
Post
Mon Aug 11, 2008 7:04 pm
Looks a little council to me..
Youth is wasted on the young.
siddiqi1
- BFG Zone Contributor
Post
Mon Aug 11, 2008 8:11 pm
fettled
i like the use of the NEW word that has now been signed in! not bad i think, cross hairs or whatever they called would do a treat!
might try this meself, loooks good!
StuBeeDoo
Post
Mon Aug 11, 2008 8:23 pm
Hyperion wrote:i want to give this a try one day too, but i was gonna go the oven route to get the lenses off.
I wouldn't!!
I did that for my first attempt and I melted the housings.
Heat-gun is the best option. I'm on my third pair of DIY's now.
tha_lick
Post
Tue Aug 12, 2008 7:46 am
Sanchez wrote:has the spray paint not made your lights dimmer?
no because i didnt spray the dipped beam lenses, i just painted the reflective bit inside. i only sprayed the high beam lenses with a coat of tint spray. i cant really notice any difference because i hardly ever use the high beams. . . that and iv got HIDs so its just always bright as heck. . .
just didnt want what everyones already got in regards to the cross hairs. well the main reason was i finished them in less than a day (apart from the smashed one) and didnt think to try and get hold of a set of cross hairs.
stonesie
Post
Tue Aug 12, 2008 5:22 pm
Crosshairs are a royal pain to fit, mine were the longest part of the job, if i do another set im going to do them in 1mm alloy i think.
