Mtech 2 kit is only really designed for the face lift model (92-93 on the cabs) front should be realitivly easy to fit, but the rear is a different story as the rear arches are different on pre and post face lift (see my picture below for facelift cab, note the rear lights)
that is not to say it cannot be fitted, quite a few on this zone have fitted tech2 on preface lift cars (also known as metal bumper models). you will need to make some modifications to the fixing brackets and to the area around the rear wheel arch. try search section for keyword tech2.
mrlee
