Service Indicator Problem
BIGJO
Fri Aug 08, 2008 9:21 pm
Hi,
I have a problem with my service indicator. Some of the green lights aren't working correctly.
Are the LED's on its way out or something?
And how do I go about fixing this problem?
Could it be linked with the bulb that has gone on my rev counter?
Any help is much appreciated.
Kind regards.
johnny_boymk1
Fri Aug 08, 2008 9:28 pm
http://www.e30zone.net/modules.php?name ... ic&t=88790
Not to sure about your service lights mate but heres a good step by step to getting the clocks out.
I`used it today to change my dash bulbs. Worked a treat.
BIGJO
Fri Aug 08, 2008 9:52 pm
Thanks buddy. I can use that info to replace my light for my rev counter :D
Fri Aug 08, 2008 10:09 pm
sounds like the leds have decided to go along with the rev counter bulb
there is a common problem with the SI board going in the instrument cluster but i dont think they effect the bulbs, but it could effect the service indicator
BIGJO
Sat Aug 09, 2008 7:59 am
The rev counter bulb has definately gone. Some of the green lights come on and go off so I think they need replacing. Just want to know how to go about it before pulling out the dash.
Thanks.
rj
Sat Aug 09, 2008 12:50 pm
Take the LED board out and check for dry solder joints. If after reheating the solder points the problem still persists, then you can pick up an LED board from a scrapyard.
**BANNED**
Sat Aug 09, 2008 1:09 pm
Could this be memory loss due to the SI board batteries failing? Still have to strip the sodding cluster but....
Youth is wasted on the young.
Sat Aug 09, 2008 2:00 pm
I very much doubt if there is anything wrong with any of the LEDs. I've yet to come across a dud one in any application.
Take the SI board out, put it in the fridge for half an hour, then measure the voltage across the batteries.
BIGJO
Sat Aug 09, 2008 3:53 pm
Will do! Thanks Brian...will keep you posted :thumb:
BIGJO
Tue Aug 12, 2008 6:09 pm
I've been bashing my dash board & they keep coming on and off :o
