M40 crank pulley!
eko
Old timer
Post Mon Jun 27, 2005 8:28 pm
anyone got any ideas?
Just cant undo the 22mm bolt to change the cambelt :mad:
tried airgun,long bar and impact socket but it aint budging.
isnt some thing stupid like left hand thread is it?
driving me mad,any ideas guys?
pmaddy00
Post Mon Jun 27, 2005 9:50 pm
Not sure about M40 engine but I undone mine a few weeks ago on M42 engine and was right hand thread.
Try this if u have tried yet!!
"Put a power bar vertically upwards on the pulley bolt and a block of wood on the LH chassis arm. Crank the starter motor momentarily (start the car) so that the bar rotates 90 degrees into the block of wood! 3-4 goes will normally release it"
Hope this helps.
eko
Old timer
Post Mon Jun 27, 2005 10:03 pm
done it!
had another go just now and managed to get it undone,but f**k me it was tight!
jonbuoy
Post Mon Jun 27, 2005 10:36 pm
If i'm thinking of the wright thing your talking about i've never had to undo that nut. Its a tight fit but the belt does go on.
jonbuoy
Post Mon Jun 27, 2005 10:38 pm
Are you changing the pulley?
eko
Old timer
Post Mon Jun 27, 2005 10:46 pm
jonbuoy
Only changing the belt/tensioner.Managed to do it in the end by using flywheel locking pin and brute force!
Dont know about not removing pulley,other wise cant get cambelt cover off?
gazza
Post Tue Jun 28, 2005 12:00 pm
bit late now but you dont need to undo the crank pulley....just the 6 bolts around it and the pulley comes off wthout disturbing the crank nut just done a belt on mine
Image design cab and now 325 touring
jonbuoy
Post Wed Jun 29, 2005 7:00 pm
Gazza
Its bin a little while since i done mine but i thought that to.
jonbuoy
Post Wed Jun 29, 2005 7:06 pm
I've just remembered!!!!!!!!!!!
6 10mm bolts and its off, the crank nut is under alot of torque thats why even an air gun would'nt get it off. There is a reason its done up so tight so i suggest you do it up to the correct torque otherwise you might find your pulley spinning past you along the road while your back wheels have locked up cos ya belts come off :hammer:
