lumpy idle
Bob_S
Post Sun Jun 26, 2005 8:17 pm
Hi all, my car idles at 800rpm, but it is a bit lumpy, any suggestyions on how to remedy this - thanks
RevBillyG
Post Sun Jun 26, 2005 10:16 pm
Standard reply to this is to clean your ICV before anything else. It's a very common complaint.
Best smiley ever-----> winkeye
Post Sun Jun 26, 2005 10:24 pm
RevBillyG wrote:Standard reply to this is to clean your ICV before anything else. It's a very common complaint.
Nah, that's for inconsistant idle.
Standard answer is blue temp sensor.
RevBillyG
Post Sun Jun 26, 2005 11:57 pm
You know, I've really got to find out more about this blue temp sensor. I'm getting a replacement AFM soon to try to sort out my strange idling (it was suggested to me by BMW of Hook) but I've not looked into the temp sensor.
Where is it? How do I test it? :)
Bob_S
Post Mon Jun 27, 2005 12:00 am
cheers, where can i find the temp sensor and also it seems to run a bit rich aswell, I have tried a new air flow meter but it's the same so I have disregarded that, I have cleaned the ICV aswell thinking that may possibly help.
being fuel injection would i be right in saying that I could reset the ecu? if so, how? cheers
Post Mon Jun 27, 2005 12:04 am
If it's running rich, that points even more to blue temp sensor.
Rough idle, to the point of stalling sometimes and running rich were the two symptoms my (very) cheap daily driver came with four years ago.
Now, if you tell us what engine you have, we'll tell you where it is and how to test it.
Bob_S
Post Mon Jun 27, 2005 12:37 am
i have a 1.6i m40 1990...
Post Mon Jun 27, 2005 9:02 am
Hmmm! That's the worst one to get at.
It's located just below inlet ports 2 and 3. i.e. 1/2 way back the left side of the engine under the inlet manifold and is not the easiest place to get.
To test it you measure the resistance between it's two terminals.
These figures are actually measured off a good sensor:
Cold water : 3400 ohms
Hot water (from tap) : 980 ohms
Very hot water :306 ohms
If your sensor is faulty, you will get higher readings than these.
In the example I mentioned in my previous post,(also an M40), the readings were about double.
Bob_S
Post Mon Jun 27, 2005 5:10 pm
cheers Brian much appreciated I will go and test it now, cheers again
kingstonbe
Post Mon Jun 27, 2005 7:44 pm
i have the same problem with my 89 325 i, its pretty lumpy, and shudders below 1500 rpm off the throttle, my air flow meter is reading up and down resistances as the flap is opened to its fully open position - i believe (and hope) that this should solve the problem.
Brian Moore -should that not work where is this temperature sensor for my motor?
Post Mon Jun 27, 2005 9:45 pm
Yours is much easier to get at.
Top front of the engine on the thermostat elbow. ( The bit with the air bleed screw on it).
zip88
Post Mon Jun 27, 2005 9:56 pm
you guessed it ,mine has the same fault,idles at about 500rpm
hot or cold and stalls,cleaned out the idle control valve but still
the same.what are the resistances for an 88 320,i think i know
where the sensor is up front on the head?
any help would be welcome
Post Mon Jun 27, 2005 11:26 pm
As far as I know, (but I've never checked), the blue sensor is the same on all E30s.
Bob_S
Post Mon Jun 27, 2005 11:44 pm
well... I'm guessing the blue temp sensor is inside the cave made by the inlet pipes, I didnt get to it but found if I blocked off a loose line which was sucking air in it was dandy, so I'm happy now! I really need to see where this line goes to though :S
still running a bit rich though?
nadz325i
Post Fri Aug 25, 2006 9:38 am
Brianmoooore wrote:Hmmm! That's the worst one to get at.
hi just wanted to confirm
i tested the blue sensor on my e30 and got the following results
Cold water : about 3100 +- ohms
Hot water (from tap) : warm water in a bowl, was decrementing got bored took it out,
Very hot water :operating water temp 180-+ ohms
is this a duff sensor? compared to brianmoores values? car does run rich, idles high.
thanks.
