OK, my e30 m42 head/valves are lunched.
Got the chance to buy a complete M42 from a 1994 e36.
Apart from the sump, the biggest problem appears to be swapping the crank damper because the e36 uses a flat profile water pump/alternator belt , e30 is V-belts.
Any thoughts on the reality of correctly changing the damper between the two engines?
Thanks, Mark
M42 engine swap: e36 to e30
bene30jane
i have just put an e36 m40 in to my e30 and had to swap all the pulleys as the position of the crank sensor missed the pick up teeth on the pulley, dont know if thats any help?....
bene30jane
swap the pulleys with your original ones inc the alternator
uzdubmwe30
OR just get a replacement second hand head, get it skimmed and do the head gasket? (Have one here)
Im putting a 1994 lump into mine and am using the single serpentine belt setup as it's 20 times better.
bene30jane
problem i found with my e36 engine was the crankshaft position sensor sat away from the pick up ring?.....
