Help fitting cruise control
clackmac325
Post Sat Jun 25, 2005 8:28 pm
Just taken the cruise control off a se 325.(what a bitch!!!!)
Im not sure if i got every thing though. Has any one got a wiring diagram for one of these??
Please help :cry: :cry:
Or point me in the right direction :D
Thanks Clack
Simon
Post Sun Jun 26, 2005 10:47 pm
How did this go? What else did you need to know?
You should have had
1. Wiring loom
2. Control unit (silver box)
3. Stalk
4. Actuator with bracket for mounting on side of airbox
5. Extra throttle cable with all fixings, should be fastened to the actuator
6. Green connector plug, plugs into back of instrument cluster
7. Clutch switch if manual
Anymore questions, fire away as I've fitted 3 of these now!
billgatese30
Post Sun Jun 26, 2005 11:10 pm
Simon wrote:Anymore questions, fire away as I've fitted 3 of these now!
edit
fitted 3, 1 minus the stalk :lol:
only kidding mate, have you posted that yyet or not??
Simon
Post Mon Jun 27, 2005 8:00 am
edit
Sorry Chris, waiting for my Jiffy envelopes to arrive!
billgatese30
Post Mon Jun 27, 2005 5:37 pm
:roll:
that old chestnut :lol:
no worrys mate
clackmac325
Post Tue Jun 28, 2005 5:36 am
Sorry for the delay in responding It looks like i have every thing.Problem is mines come off a auto and id like to fit it on to a manual.
The plug that goes to the brake peddle was bridged using a piece of wire!!!!
Thing is when i drove the car it worked???
To remove it i had to take the whole dash out.Do i have to remove the dash to fit or shall i run the wires another way?
Also it plugged into a big connector behind the glove box.Is this where it draws its power???Does my car have the connector so i can just plug it in?
What number fuse holder is it?What amp??
Some people sell some sort of cd that has the parts listings on.Would this have the wiring colour codes?The Haynes manual doesnt cover the cruise control loom.
Fcuk it how much you gonna charge me to fit it??? :cry:
Thanks for the help :D
Simon
Post Tue Jun 28, 2005 8:15 am
You shouldn't have needed to remove the dash to remove it all, you can run the wiring which ever way you like though.
To fit the set up to your manual car, you will have to get a switch and bracket part numbers are
Bracket 65 71 1 385 084
Switch 61 31 8 360 421
You will need this otherwise if you have the cruise engaged, and you depress the clutch the car will just rev to the redline and stay there until either you switch it off manually or the engine goes pop!
The big connector you mention will be on your car, the connectors are all unique, so the cruise shoud fit into one of yours no problem.
No fuses, it's all there waiting.
Don't have to worry about wiring colours, it's all plug and play!
clackmac325
Post Tue Jun 28, 2005 8:17 pm
Cheers. Ill have a proper crack at it when i get back off my hols.I dont want to rush it.Nice one for the part numbers.
Im just not that good when it comes to putting things back together :oops:
Simon
Post Tue Jun 28, 2005 8:20 pm
clackmac325 wrote:Cheers. Ill have a proper crack at it when i get back off my hols.I dont want to rush it.Nice one for the part numbers.
No worries, if you get any probs in the process, either post up here, or PM me.
