under bonnet soundproofing...
320Touring
51488103798- that the part number?
I can run into the dealer on wed and find out for you?
fuzzy
not sure of the part numbers for the 3 bits neil.it shows them on the diagram but doesnt list them at all.ill give them a phone in the morning but thanks for the offer anyway.the 3 parts are still sodden with oil after forgetting to put the oil filler cap back after topping it up a couple of months ago and its slowly dripping out and spraying back over my engine bay,doesnt look good on my freshly painted white rocker cover320Touring wrote:51488103798- that the part number?
320Touring
ahh right!
good luck finding out, and hope that he YB gets to be oil free soon
is it that nice black ridged quite solid heat proof foam?
the 'is' has it and it looks really well.
the 320i has some scabby old cream stuff and looks awful - didnt realise it was available at all....
can generic foam be cut to size for the job?
320Touring
good work sirfuzzy wrote:simon was very close with his guess,ordered the 3 pieces today from bmw at a cost of £26 +vat.surprisingly cheap from a main dealer
nice remembering simon
fuzzy
probably could but the oil was soaked right through the sponge,ive powerwashed it in place before but it hasnt removed all the oil and it keeps gathering at the lowest point,dripping and spraying back over the engine.
march109
- Contact:
Mine has started to melt to my strut brace
Also it was only a few weeks old and I used spray mount to stick it up I can't pull the damn thing off now!
I fitted a new set for my old 320 a few months back, bought from the local dealer - my current one fell loose so a bit of carpet tile spary soon sorted the problem
BTW - be careful when sticking on the new foam, the sticky side is proper stuff !
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
As above - self adhesive - comes as one big piece, you just peel off each of the 3 sections and stick on, couldn't be simpler
BTW fuzzy, thanks for the info on me prop shaft
Sorry to go slightly off thread there
fuzzy
its ok, its my thread so i can take it as far o/t as i wantfingerman wrote:BTW fuzzy, thanks for the info on me prop shaft
what did the problem turn out to be? was it the bearing?
Not checked it yet as I'm down in sunny Southampton - will be getting underneath at the weekend (when it's probably raning !) - will let you know
