Flat spot, help! :(
coldo
Post Mon Jun 27, 2005 1:52 am
My car has an annoying flat spot at high0ish revs :(
In nuetral, it will rev to redline (6k rpm)
In first , it will rev to the redline
In second, it will rev to 5k
In third, it will rev to 4k
in 4th, it will rev to 4k
If i keep the foot down, it usually gets to around 5k, then begins to die again :banghead: :(
Its not a major problem, as im rarely at that high rpm, but when im giving it some, it does my head in having to change up at 4krpm :( :oops: more annoying than anything!
Anyone any ideas what it is/how to fix it? :?
Its an M40 engine by the way (316i) :(
coldo
Post Mon Jun 27, 2005 11:39 am
Bump, this gets more annoying everytime i drive the car :cry: :x
320Touring
Post Mon Jun 27, 2005 11:48 am
Like i say, the reluctance to rev under load will probably be the camshaft being worn.
Up to you whether you get it fixed (expect a bill of 2-300) or live with it..
Its very common on the m40 engine :cry:
