saab radiator fitted, slotted in nice and easy
also got a twin speed relay setup from a laguna, need to get a temp switch to hook it up tp the radiator!!
anyone doing a m50 swap should definately change the water pump, i had so much headache today with over heating and steam, so took out the water pump and it had no fins left, the knuckle was rounded off,
luckly they were still in the chamber!! couldn't get hold of a pump today, everywhere was closed, i had a m20 pump lying around, took the metal fins off that and fitted'em to the m50 pump, no more over heating and 30 odd quid saved!!
