As above really, mine seems to be leaking.
1989 E30 325i
Oil pressure switch
powelly
Le Mans Classic 2006-
zimmerbimmer1
- BMW Parts Meister
Oil Pressure Switch £8.25
Have you checked the valve on the oil filter housing that is common to leak as well £5.77
powelly
I'll have a look.
powelly
On closer inspection I think you might be right Paul, the rubber boot on the switch was full of oil which, from what I can tell the oil looks to dripping from above it out of the filter housing just behind the right hand oil cooler hose.
As well as the valve could you please price up the big O ring and the two washers that go on the big centre bolt for the housing.
zimmerbimmer1
- BMW Parts Meister
The Valve £5.45
the seals and o ring £4.12
powelly
Hi Paul, I just wondered when the parts might be arriving.
zimmerbimmer1
- BMW Parts Meister
The items were sent in the post to you yesterday.
