cam not switching!
Flamez
I have just had my engine changed on my 318is H reg a G reg engine has been put in and it's not switching over from the small cam when revved it just limits itself around 3krpm. what can it be? i think he tried changing the camshaft sensor but its still the same. Please help its been a year since i have had my car and i really miss it
318is
original ac schnitzer 16" wheels
original oem IX coupe bodykit
aftermarket mod: viper fast road chip
aftermarket mod: clifford intellistart + dual zone
car for sale soon!
car for sale soon!
Martinaston
Can you explain what you mean by not swithing from small cam ?
Flamez
sorry what i mean is when i drive the car where it usually changes cams when revved up to around 3000rpm and starts pulling harder it justs starts choking and i have to change gear to keep the revs low, i cant rev up. i have to drive it in low revs on every gear. my mechanic thought it was the camshaft sensor but he changed it and it still has the same problem.
318is
car for sale soon!
car for sale soon!
Martinaston
The way i understand it you have two cam shafts.
One for the inlet valves
and one for the exhaust valves
If your mechanic told you otherwise i would surgest finding another mechanic
As to the problem have you checked the distributor cap for wear ?
Flamez
sorry i just assumed that was how it worked. everything has been changed e.g. airflow meter. ignition pack. do you know anywhere i can take it. I live in hackney
318is
car for sale soon!
car for sale soon!
Martinaston
anywhere apart from the original mechanic
