Hi Paul, thanks for the weber base plate last week!
Can you supply the gasket also between the base and the carb as the old one turned to mush.
It was a 1987 316
Just noticed a chip in the glass of my drivers side main beam, can you give me a price for this also please.
Thanks, Brian.
weber gasket
zimmerbimmer1
- BMW Parts Meister
Is it the gasket on this link clickyflugel wrote:Hi Paul, thanks for the weber base plate last week!
It was a 1987 316
Thanks, Brian.
flugel
No, it's the final item at the very base of the carb to seal against the base you supplied-so not showing on that link.
zimmerbimmer1
- BMW Parts Meister
On my system there is no other gasket between the carb and the part i supplied you may need to go to webber carbs themselves as the webber carb is not an oem part.
Is your car pre or post facelift for the headlamp glass?
