Buzzing Gong
matcox77
Post Thu Jun 23, 2005 10:22 pm
Does anyone know why item 10 in the following link
http://www.realoem.com/bmw/showparts.do ... g=62&fg=40
should start buzzing all the time?
To stop it I have removed the connector from it next to the headlight level adjustment. No idea why it has started this all of a sudden. I think it is part of the OBC but that seems to be ok.
Thanks,
Matt.
Sjoerd320i
Post Thu Jun 23, 2005 10:25 pm
have you changed any setting on your obc lately?
that could be the problem
matcox77
Post Thu Jun 23, 2005 10:33 pm
No not changed anything, I don't even know how long it has been buzzing for, it was fine when I parked up on Sunday and when I opened the car last night it was buzzing. When I got in from work tonight it was the same so I have disconnected it until I have time to look at it on Saturday.
It's strange how is has just started.
Matt.
Sjoerd320i
Post Thu Jun 23, 2005 10:34 pm
sorry mate can't help ya then :(
hope someone else one here can help you out so you can sort it :wink:
cheers Sjoerd
matcox77
Post Thu Jun 23, 2005 10:38 pm
Thanks Sjoerd,
Im sure someone will know what is going on. I may just disconect the power to the OBC for a bit and see if it starts up again ok.
Matt.
Widge
Post Thu Jun 23, 2005 11:37 pm
Yep thats the OBC gong, it gongs every time it is earthed so check the earths between it and the obc. Otherwise it's probably buggered :cry:
Post Fri Jun 24, 2005 9:27 am
This happened to me. I fixed it, but I'm bug***ed if I can remember how!
