ANY IDEAS PEEP'S? BRAKES....
MrBMW78
Thu Jun 23, 2005 6:42 pm
HEY EVERY 1.
I HAVE RECENTLY CHANGED ALL MY BRAKES(APPROX 3MTHS)...PADS/DRUMS/DISCS/AND THE PUMPS....ALL BRAND NEW!!!..PURCHASED FRM A BMW SPECIALIST....LET THEM WEAR IN AND STILL..... :-x
OK HERE IS THE PROBLEM. THEY SQUEEK LIKE HELL....SOUNDS LIKE A FUCKING BUS SOMETIMES.
LOW BRAKING AND HARD BRAKING...DAM BRAKES STILL SQUEEK....WHAT COULD THIS BE?
HELPPPPPPPPPPP
320Touring
Thu Jun 23, 2005 6:48 pm
MrBMW78 wrote:HEY EVERY 1.
OK HERE IS THE PROBLEM. THEY SQUEEK LIKE HELL....SOUNDS LIKE A fudge BUS SOMETIMES.
HELPPPPPPPPPPP
possibly the pads moving about
get some copper grease and apply to the back of the pads and it may quieten it down
Thu Jun 23, 2005 6:54 pm
are the disks glazed? maybe some brake cleaner will sort things
TOURINGDADDY
Thu Jun 23, 2005 6:58 pm
Do what i do turn the music up :lol:
on a more suitable note make sure that there is no crap on the hub behind the discs and check that the fittin kit on the rear shoes has been fitted propperly and not touchin the inside of the drum or the inner hub
A1BMW325iSport
Thu Jun 23, 2005 6:59 pm
yep i agree a good dose of brake cleaner is the best bet
MrBMW78
Thu Jun 23, 2005 7:13 pm
WILL DEFINATELY TRY THE BRAKE CLEANER......
ANY BRAKE CLEANER FRM SAY HALFORDS WILL DO RIGHT? THANKS ALL
bullitt
Thu Jun 23, 2005 7:17 pm
If you have disc's all round remove the pads and give the braking surface a scrub with 80grit sand paper to take the glaze off the pad then apply some copper grease to the backing plate face
For rear drums chanver the two edges of the brake shoe lining with a flat file and blow any excess brake dust out off the drum area..
No more squeal!!!!!!
ZS
Thu Jun 23, 2005 7:21 pm
Anti-squeal shims might be a good idea too.
Once driven, forever smitten.
Direct injection, turboed, intercooled, 16 valves giving a whopping 48.5hp/litre!! :(
MrBMW78
Thu Jun 23, 2005 7:26 pm
bullitt wrote:If you have disc's all round remove the pads and give the braking surface a scrub with 80grit sand paper to take the glaze off the pad then apply some copper grease to the backing plate face
YOUR REPLY IS DEFINATELY WORTH GIVING A GO.....CHEERS
Shinobi1
Thu Jun 23, 2005 7:41 pm
Hi there ,worth taking the pads out cleaning the surface with emery cloth then file a chamfer on the pad edges and finally copaslip the backs and the ears of the pads.
cheers paul
jamesroools
Thu Jun 23, 2005 7:50 pm
i had a similar problem b4 on another car, the problem turned out to be badly bent caliper slide pins, it looked like whoever done the brakes used a hamer to put them back together, causing the brakes to be not making the correct contact with the discs, if all them cures dont work, try replacing the caliper slide pins, i believe the parts are actually part of a brake caliper carrier kit and arent available seperatley
Image Image
MrBMW78
Fri Jun 24, 2005 1:15 am
jamesroools wrote:i had a similar problem b4 on another car, the problem turned out to be badly bent caliper slide pins, it looked like whoever done the brakes used a hamer to put them back together, causing the brakes to be not making the correct contact with the discs, if all them cures dont work, try replacing the caliper slide pins, i believe the parts are actually part of a brake caliper carrier kit and arent available seperatley
Cool...will try the easy things 1st.and if no joy..will def give it a go....cause maaan the blasted noise pisses me off!.
thanks dude
