Adding PAS
Guest
Post Tue Jan 25, 2005 5:12 pm
Hi
I have E30 318 Baur cabriolet. It was never fitted with PAS. How easy is it to put in and what will I need?
Ant
Retired Team Member
Retired Team Member
Post Tue Jan 25, 2005 5:23 pm
you'll need the pump and fittings, plus a good used rack to make the swop.
best bet is a breakers that could supply a kit of parts, the fitting is mainly a nut and bolt job ,
Try Jon B on the forum, he may just have all that you require, he normally does :wink:
charlE30
Post Tue Jan 25, 2005 5:58 pm
As ant said try jonb :rock:, bought my complete setup from him last year (rack, pump+bracket, hoses, reservior+bracket) still haven't got round to fitting it though, :cheese: weather. It was around Ԛ£125ish.
Another place to try is www.partsgateway.co.uk and they'll search all your local breakers for free.
BMW F31 335d xdrive
charlE30
Post Fri Jan 28, 2005 6:53 am
garyo check out http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... RK:MEWA:IT looks like what your after :thumb:
BMW F31 335d xdrive
