Subframe bush alignment.
tomstickland
Tue Jun 17, 2008 5:20 pm
I'm got all the subframe apart so I can replace the brake lines. I'm also replacing the bushes.
Which way should then be aligned? I'm referring to the way that they can be inserted at any angle, and have clear cut outs which I assume need aligning.
Tue Jun 17, 2008 5:24 pm
they only go 1 way, as the beam has 2 lumps in the holes for the bush to locate with it's grooves
tomstickland
Wed Jun 18, 2008 10:58 am
Sorted.
I haven't got the old bushes out yet - left the blow torch at a friend's house so have to go and buy one of those now.
Wed Jun 18, 2008 1:57 pm
Buy a hole saw instead!
Chase007
Fri Jun 27, 2008 11:02 pm
Is there a guide to fitting these subframe bushes and the others? :)
psychochild187
Wed Jul 02, 2008 12:08 am
if anyone wants to come my way i have a tool that pulls them out in no time atall with out removing anything from the car but the rear seat and small plate
im in brighton area
