17 inch Pinas
MaK-71
Post Tue Jan 11, 2005 3:59 pm
howdo folks
Decided to get some Pinas for thre Tourer.
I have been offered some shabby 17s (will B mint with refurb).
My only concern is that I may run too low when loaded up!!?? The motor has already been dropped on eibach pro springs /matched with standard bilsteins.
Anyone running 17s is it ok? or should I wait for some 16s to come along??
cheerzzzz MaK :roll:
Post Tue Jan 11, 2005 4:01 pm
what do you mean by run to low?! the rolling radius will be the same as the standard wheels...
Davenotouring
Post Tue Jan 11, 2005 4:04 pm
I've got 17's on my Touring, lowered 40mm. There is no rubbing at all any time even full up with people and luggage.
The seventeens will raise the car slightly.
BMW 328i Cab - Daily Slag
Jimbob
Post Tue Jan 11, 2005 4:15 pm
as Jhonno said, the rolling radius is barely affected, i went from 195/60/14 to 205/40/17 - after sitting a wheel of each size on each other there was actually no visible difference.
MaK-71
Post Tue Jan 11, 2005 4:42 pm
Ahhhhhh It all becomes clear now bigger the wheels, less tyre depth.
So what tyres do you recommend 205/40/17 215/40/17 or 245/35/17
or wider at the back than front.
MaK :wink:
Post Tue Jan 11, 2005 4:43 pm
215/40's are the correct size iirc
Davenotouring
Post Tue Jan 11, 2005 4:44 pm
I've got 205/40 17's all round. I can't comment about if 215's would rub cos I'm not sure. Mine gives good enough handling though as it is.
Guest
Post Tue Jan 11, 2005 5:05 pm
i'll second Dave there i have 40mm drop and had loadsa wood in my car and was worried about rubbing and it doesn't happen even when you stick the boot in...
MaK-71
Post Tue Jan 11, 2005 5:15 pm
Cheerz guys 8) :) :twisted:
zaust
Zone day release
Post Tue Jan 11, 2005 6:35 pm
There's plenty of weight in my boot and with 3 in the back it's fine down 60mm 215/40/17.. no probs.
M30 Tech 1 Touring on gas.
greg325
Post Tue Jan 11, 2005 6:52 pm
i used to use 220 50 15 for 1/4mile, at the back but when loaded ( on the way to the race course ) the 225 hit the wings....215 is defenatly the widest without doing any bodywork....
Russ
Post Tue Jan 11, 2005 9:37 pm
Yeah? You wanted me?
Oh Im sorry, I thought you said 17 inch penis. :lol:
Davenotouring
Post Tue Jan 11, 2005 10:26 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
8O
You joker!
Richy325iTouring
Post Wed Jan 12, 2005 7:33 am
As ong as the rotation the same or nearly you be ok
heres a link to check
http://www.miata.net/garage/tirecalc.html
