This is an E34 guard, different tubular mounting arms but the pressed plate is the same piece as used on the E30 guard, just with the cut out for the drain plug in a different place.
Starting from the front edge
Across the forward bend
This is the rear mount holes centre to centre
Rear edge
Front edge to rear edge
And this is from the front bend to the rear edge
