front fogs
- tomcat9999
will my e30 318i 1990 be already wired for front foglights? at the moment there are blanking plates where the fogs should be, also the foglight switch is a single one for the rear.
Here's the info i was given when i fitted a set on my old 320i
http://www.e30zone.net/modules.php?name ... =foglights
89 325i touring
- tomcat9999
Cheers will give that a go thanks for the reply
BadDave
You'll need 2 fuses(7.5 amp iirc)e30-320i wrote:The wiring should all be there mate tucked up just below your headlights.Then you just need the double switch and a fuse i believe
Double foglight switch
Relay
and you also need the fixing screws and the plastic clips that they go into as well
Wiring should all be in place IIRC
HTH
- Brianmoooore
And a little bulb assembly for the warning light position on the instrument cluster.BadDave wrote:You'll need 2 fuses(7.5 amp iirc)
Relay
BadDave
Forgot about that oneBrianmoooore wrote:And a little bulb assembly for the warning light position on the instrument cluster.BadDave wrote:You'll need 2 fuses(7.5 amp iirc)
Relay
- tomcat9999
cheers for the replies what relay do i need are they standard ?
- Brianmoooore
Unfortunately it's not the same as the most common type of relay. It has to be the same as K4, with two normally open contacts and five pins. NOT to be confused with a five pin changeover type.tomcat9999 wrote:cheers for the replies what relay do i need are they standard ?
- tomcat9999
everything done except fixing bits and screws also struggling to find proper relay, local motor factors sold me one they said was correct and i plugged it in and nearly set car on fire . any ideas where i can get these bits from ta
BadDave
Contact zimmerbimmer inn the genuine parts section(in a parts dept)tomcat9999 wrote:everything done except fixing bits and screws also struggling to find proper relay, local motor factors sold me one they said was correct and i plugged it in and nearly set car on fire . any ideas where i can get these bits from ta
The relay is still available iirc
One from an E36 does the job,can't remember the part number tho
He may be able to supply the plastic fixings and screws as well
SPADGE
I can post you one if requiredtomcat9999 wrote:everything done except fixing bits and screws also struggling to find proper relay, local motor factors sold me one they said was correct and i plugged it in and nearly set car on fire . any ideas where i can get these bits from ta
