Just bought E38 alu Brembo calipers, want to fit them with Audi S3 rotors 312x25 mm, just 4 hole 4x100 and center drilling needed
I've seen that setup on R16 rims
4 pot calipers..
- Homo Hair
324mm with the 840i brembo fits under 16's but it needs something like Compomotives to work with the back spacing
iil325i
a full kit, look at my add. its a will woodkit to fit under 16" wheels, there is everything you need.
uvels
here is Brembo 2 piece 312mm rotors,brembo 4 pot calipers on e30
oze30
Uvel, what offset is that bell? I need colse to zero offset on the bell. At the mo it's roughly +20mm, requiring spacers behind and in front of the disc. if i can get a 0 ish offset bell, I'llonl need a 0-15mm spacer on the front.
